Thread: 70S suspension restoration question
    Junior Member
    Apr 2012
    San Diego, CA
    The front sway bar stabiliser levers and all four rotor dust covers are in very good shape and are the original gold color. They are not quite as shiney as I have seen in pictures posted on this board. My question - should I consider just cleaning them up and restoring the rest of the suspension.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    If the plating hasn't broken down I'd just clean them. The original finish is/was Cadmium which is getting harder to find someone to do.
    I think you'll find that most people zinc plate, which would explain the difference that you're seeing.
    Atlanta, GA
    Don't be too aggressive with whatever you do bc the finish is very thin and what looks good now will quickly change on you with too much scrubbing.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  1. Suspension pans 69-73 Stoddard vs. Restoration Design
    By Sundevil64 in forum Technical Info
    Last Post: 12-21-2013, 02:02 PM
  2. Suspension component restoration
    By spankie in forum Technical Info
    Last Post: 04-28-2012, 01:53 PM
  3. Another SWB Front suspension question
    By MTemp in forum Technical Info
    Last Post: 07-25-2011, 08:52 AM
  4. Front suspension question
    By tar356 in forum Technical Info
    Last Post: 01-04-2010, 02:38 PM
  5. Suspension Set-up Question
    By Paul W in forum Technical Info
    Last Post: 07-08-2006, 04:23 PM
