Results 1 to 10 of 15
Thread: I assume I am missing something - swb door latch
    Feb 2011
    Surrey, UK
    Something tells me that when my door latches came back from being plated, despite what Mr. Plater said, something has dissolved in the process.
    Am I right in thinking there should be another piece of plastic/rubber/bakelite etc in the bottom section of my door latches - see photo below?
    I say this because when the part on the door itself - the lobed shaped bit - goes into the latch there is nothing to start it turning down, and so it just contacts the metal surround for the bottom bolt that you can see in the bottom of the photo.
    If so can anyone take a photo of the inside of a correct latch so I can see what I'm missing. I assume this insert is unobtanium, and that latches are NLA and that secondhand ones are rarer than a rare thing, and more expensive than a really expensive thing - so I'll be making an insert out of acrylic plastic or something and super-gluing it in there. Any dimensions or diagrams that anyone is prepared to make would also be really helpful.
    And refitting the doors was going so well.....
    Mick
    Jun 2010
    CT US
    Yes missing the bottom plastic peice
    I just replaced mine easy easy .
    the door would not close.
    now working good.
    Ecklers had them for 21 bucks. but they are black now
    Feb 2011
    Surrey, UK
    Thanks, thought so.
    When you say replaced - with new or with a DIY insert? If the latter any tips on shape, what you made it from etc etc?
    If new .... who are Ecklers, as I've not heard of them before
    Mick
    Try to find a Weltmeister kit. They are the white but I believe NLA, so you have to find some old stock.
    Richard
    Jun 2010
    CT US
    Yes i just replaced the insert plastic peices. they were dry rotted and crumbled.
    one kit comes with the upper and lower plastic peices. the SWB splits apart very easily
    Eckler automotion catolgs parts
    http://www.automotion.com/striker-pl...1965-1968.html
    Jan 2003
    UK
    Mick - you can buy 'striker repairl kits' for swb models from various places here in the UK such as Roger Bray, etc.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Mick, do not worry. You should disassemble the strikers, the back metal piece pops off the cover with gentle persuasion. Inside you will find a couple of bolsters that the screws go through, a spring, and the two piece plastic latch. The latch repair kits are available. Don't lose the spring or the bolsters. You should remove all rust and gently polish the striker cover-- the plating will not cover any surface imperfections, so start with a finish that you want to end up with.
    You should also source some correct oval-head, philips-drive M8 screws. The ones you have are 67-
    Feb 2011
    Surrey, UK
    Thanks to all for your responses - I will get a repair kit from the UK.
    Re the above, well this car has been up to now about as original as it is possible to get, and these are what was on the car so I'm fairly sure they are too. There was no evidence that the latches/striker plates had been replaced and the 12 spline screws are the same on both sides.
    Mick
    Seattle WA
    There's an overlap on this latch with the Karmann Ghia. This parts page may be of some help to you, or not....
    http://www.mtmfg.com/category/view/92
    striker rebuild parts
    Stoddard has a rebuild kit with spring and white plastic parts.
  1. Glove box latch missing... latch
    By Eminence Gris in forum Technical Info
    Last Post: 04-05-2015, 02:54 PM
  2. door latch position ?
    By Xavier PJB in forum Technical Info
    Last Post: 10-17-2012, 07:47 AM
  3. FS: Early 911 Right Side Door Latch from a 66
    By rennmark71 in forum For Sale: 911 Parts
    Last Post: 07-13-2011, 07:25 AM
  4. WTB: '72 Oil Door Latch
    By CPRSteve in forum For Sale: 911 Parts
    Last Post: 02-08-2010, 02:55 PM
