Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Bosch HKZ
    Senior Member mrg3.6's Avatar
    Nov 2007
    United Kingdom
    Bosch HKZ
    Knowing that the original Bosch HKZ unit in the early 911S was essentially introduced to eliminate 'plug fouling', can some kind soul please explain in simple terms to a (completely inept) layman the key 'evolutionary' differences between the 3-pin, 6-pin and 8-pin Bosch HKZ CDI units and what performance or other gains each configuration brought to our 6 cylinder oily bits?
    Thx
    Martin
    no difference in spark output
    difference in how they are triggered
    3 pin triggers with points
    6, 8 trigger with magnetic reluctor wheel
    Nov 2007
    United Kingdom
    no difference in spark output difference in how they are triggered 3 pin triggers with points 6, 8 trigger with magnetic reluctor wheel
    Got the points bit thanks and interesting to note there is no difference in spark output (which I didn't expect), so what distinguishes the 6 pin from the 8 pin (early turbo and RSR)?
    Martin
    8 pin has separate ground and power wires for coil terminals, unlike six pin which has a single wire to the coil output and uses a common ground. That and the price.
    so the RSR's didn't use points?
    3,0 RSR had a Bosch breakerless distributor (reluctor-triggered, no points). However, you can trigger an 8-pin with points so I'm sure there are exceptions to the "rule."
    Nov 2007
    United Kingdom
    Is there a good reason for separating the ground and power?
    Does the 8-pin unit have 'built-in' circuitry to accomodate an adjustable 'rev limiter' or is this feature limited to the RSR variant?
    Thx
    Martin
    Nov 2007
    United Kingdom
    8-Pin RSR
    Again forgive my ignorance but what does the (third) 6-pin box bring to the 8-pin twin plug party:
    (Photo's courtesy of elevenparts)
    Martin
    Feb 2011
    Surrey, UK
    It's a cdi from a 924 or 944 I believe.
    Nov 2007
    United Kingdom
    Quote Originally Posted by MTemp View Post
    So what's it doing in a 75/76 RSR ?
    Thx
    Martin
  1. FS: NOS Bosch early wiper blades with the bosch symbol
    Last Post: 10-21-2014, 12:41 AM
  2. Replies: 1
    Last Post: 08-25-2013, 07:58 AM
  3. Replies: 2
    Last Post: 10-04-2012, 09:31 PM
