Results 1 to 8 of 8
Thread: 67 911 S SWT body numbers
    Ran across the last three digits of the VIN today in both headlight buckets. For those deep into early Porsche trivia this is probably nothing new. But what it means to me is that the early car fenders and doors were fitted to the specific car, and from the looks of the narrow gaps on this car, and the fenders never having been removed it certainly shows.
    Roy Smalley
    member 877
    Seattle WA
    Looks like it has the tabs for the later headlights? Were they added, or are they original to the headlight buckets.
    Eric
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    i wondered about that too,if you look closely looks like tabs were welded in,for fittment of later head lights?
    registry #2072
    Hi Roy, the SWB cars would have the fenders fitted then a couple dowels were fitted so that the fender was perfectly lined up when refitted to the car.
    Nov 2006
    S. F. Bay Area
    That's right. As the body shop fitted doors, fenders, etc, they could 'reject' ill fitting pieces, which usually found their way into the spare parts inventory. Once fitted, they were stamped to ensure replacement on the correct car. They don't build 'em like that these days, eh?
    Brian
    S Reg #1032
    old softie67S
    Feb 2007
    Sanibel Fl
    Ed
    on 356, the factory would drill the hood hinges to insure being able to reinstall the panel. When you say on a 911, they install dowels, where and what size are they. Never noticed them. Anyone have an image?
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    Sep 2008
    Portland, OR
    Here are a few pics from my '67. Don't have the dowel size... if I'd have to guess I'd say 3-4mm, but you can see approximate location...
    Name:  fender dowels 006.jpg
    Name:  fender dowels 004.jpg
    Patrick... Member #1707
    '58 356
    '67 911
    '69 911
    The first volume 911 shop manual covers this. The rivits are 5mm and are to be mounted (2 per fender) when fender is fitted then brazed to the inner fender panel as shown above.
  1. Numbers stamped on NOS body parts?
    By blue72s in forum Technical Info
    Last Post: 05-16-2011, 06:55 PM
  2. Porsche Part Numbers to Bosch Part Numbers
    By FL-Frank in forum General Info
    Last Post: 06-28-2009, 08:56 PM
  3. Numbers numbers again...
    By BlutorangeS in forum Technical Info
    Last Post: 10-09-2008, 10:31 AM
  4. VIN numbers and dash rail numbers
    By davidppp in forum General Info
    Last Post: 08-21-2007, 09:01 AM
  5. Help with numbers
    By gilbert911 in forum General Info
    Last Post: 06-21-2007, 07:07 AM
