Results 1 to 9 of 9
Thread: 1965 911 Windshield Washer Fluid Pump
    Junior Member
    Jul 2011
    Calgary, Alberta
    I am restoring a 1965 911. When I started the project the car did not have a windshield washer fluid pump. i have one to install but am not sure where and how it is to be installed. I know it goes near the washer fluid reservoir. Where and how is it secured to the car? How is it wired in? If someone has a similar car a couple of photos would be of great help. Thank you.
    Feb 2011
    Surrey, UK
    Quote Originally Posted by dad-ladproject View Post
    I repaired the bracket on my restoration.
    It looks like this, and the washer pump is attached to it with two white tie-wraps
    And it goes on the tank support next to the front slam panel here - you can just see it in the middle of the photo next to the washer bottle support bracket.
    Hope this helps
    Mick
    Feb 2011
    Surrey, UK
    Might be easier to see here
    Sep 2006
    La Quinta
    I've never seen a '65 pump there. Mine is up close to the bag. I'll try to get photos later.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Feb 2011
    Surrey, UK
    Should have said mine was a June 66 build - thought that was the same for a 65, but John clearly knows better. Sorry for any confusion.
    Mick
    1965 Washer pump location
    The washer pump is up under the cowl, passenger side. The bracket stand off looks to be the same as the 1966/1967, Mtemp shows in the pictures above. It's the companion to the washer bag in the fender/wheel house area.
    When the rectangular plastic bottle (one year only) moved to the front latch panel the pump moved to it's location in front of the battery.
    Mtemp, good documentation of that front area - the tank and it's stand changes again in 1968 to the round tank that has the lid sticking out of the latch panel.
    Bob
    Early S Reg #370
    Quote Originally Posted by MTemp View Post
    Mick
    Actually it's the same but for the later build 1965 cars, somewhere in the 'considered' MY 66.
    Richard
    Oct 2010
    South Carolina
    Very cool stuff. Can someone post equally detailed photos of 68 car? Thanks
    Bryan
    Junior Member
    Jul 2011
    Calgary, Alberta
    Thank you all! Mine is similar to the photo provided by Bob 67S. That is exactly the photo i needed.
  1. FS: 1964/1965 windshield washer bag and pump
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 03-28-2023, 09:42 PM
  2. Replies: 27
    Last Post: 01-25-2014, 10:30 AM
  3. Windshield Washer Fluid Tank Filler for 1965
    By Bobs 67S in forum Technical Info
    Last Post: 08-07-2010, 10:36 AM
  4. '67 SWB windshield washer pump - help
    By 911kiwi in forum Technical Info
    Last Post: 09-09-2009, 02:18 AM
