Thread: Transmission Rebuild Kit - Seal Help
    Aug 2006
    Chicago area
    I recently rebuilt a 901 transmission with a custom gear setup and am getting ready to install it in my car. I used up almost all the seals in the kit from Stoddard, but have these two left over and want to verify where they go. The larger O-ring looks to be the speedo drive seal and seems to fit there. It is 30mm OD and a knowledgeable source believes that this is correct. Can someone here confirm this?
    The second seal is about 18mm OD and I do not have a clue where it goes. Any help? Ed....? Thanks.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Scott, that radial seal is probably the shift rod seal in the nose cone, sounds like about the right size.
    Aug 2006
    Chicago area
    Thanks Ed. That seal is too small for the shift rod. Plus I also replaced it. It looks just the same but smaller. Do you agree that the larger o ring is for the speedo drive?
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Sep 2008
    Portland, OR
    Scott, if it's too small for the shift rod, other place it could be used would be within the speedo drive. The o-ring should be right for the outer seal of the speedo drive, the radial seal is inside.
    Patrick... Member #1707
    '58 356
    '67 911
    '69 911
  1. Transmission rebuild clinic, Feb 8-9, Charles City, VA
    By Dr Evil in forum Technical Info
    Last Post: 12-25-2013, 07:57 PM
  2. Transmission rebuild recommendation
    By LV911 in forum General Info
    Last Post: 08-24-2013, 09:14 AM
  3. 915 transmission rebuild service
    By merbesfield in forum General Info
    Last Post: 12-31-2012, 04:26 PM
  4. DIY transmission rebuild?
    By dhopkins in forum General Info
    Last Post: 01-21-2006, 08:12 AM
  5. transmission rebuilt, 3,000 miles later, another rebuild
    By noradiator in forum Technical Info
    Last Post: 02-02-2002, 10:50 PM
