Thread: what adhesive for window seals/doorframe channels?
    What adhesive do you guys recommend for the quarter window window-to-frame seals and to secure the window channels?
    Thanks for the info
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Feb 2011
    Surrey, UK
    Any high temperature contact adhesive for the window channels. I used Dum-dum sealer (UK) for the quarterlight glass as it is black, mildly adhesive, but never quite sets hard, so it is possible to get the glass out again if needed. If you use any silicone based sealant my concern would be removal if ever necessary. I think you'd break the glass - it is hard enough to get them out as it is!
    Mick
    Thanks Mick- this adhesive/caulking would sit between the seal and the frame of the quarter window so it would not touch glass. Just looking for something that won't lump up and is relatively clean to use. I'll look into your suggestion- thanks again!
    Marco
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    3M always seem to make the best adhesives.
    - Brian
    1966 Mercedes 250SE Cab
    If you're speaking of the rear quarter glass seal, and the window channel for the door window, then my answer is none, in both cases.
  1. Door/Window seals?
    By A.T. in forum Technical Info
    Last Post: 02-28-2014, 12:49 PM
  2. Need help with window seals
    By vickcraw in forum Technical Info
    Last Post: 01-27-2012, 05:47 PM
  3. WTB felt window channels for 912 1966
    By Milou in forum For Sale: 911 Parts
    Last Post: 03-16-2011, 12:04 PM
  4. FS: 911 SWB quarter window seals
    By typ901 in forum For Sale: 911 Parts
    Last Post: 02-01-2006, 11:56 AM
