Thread: 69 Non RS
    69 Non RS
    Hi All,
    I bought my 69 912 for the all of the suspension mods and because it had a strong 3.0 SC engine wiht Webers. I love the car and the way it performs, but the PO gave it an RS look with a duck tail, front RS bumper, and graphics. However, he did not change the rear fender flares. I like the RS look but wanted something different. So, I installed a stock deck lid and front bumper and removed the graphics. I have a set of 7x16 Fuchs that are stripped to bare aluminum that will be installed shortly. I will also remove the black paint from the engine grill, and the front and rear glass trim.
    One reason for the change is that I bought the car for autocross, and the ducktail is of zero value on the AX course, but the added points would bump me up into a higher class. Also, I prefer the clean lines of the 901 without the additional aero stuff.
    Here are a couple of before and after pictures.
    John Dimock
    Senior Member ghost1001's Avatar
    Apr 2011
    West Caldwell NJ
    Looks better "cleaned up" the way it probably should be run.....please remove the 935 mirrors when you get a minute
    is it silver? seems to have a slight green tint on my screen anyway....
    Best of luck.
    Kevin
    Member #2239
    '76 911 turbo lightweight
    '87 land rover D110
    Hi Kevin,
    Yes, the mirrors are coming off. I'm considering installing Raydyots. And the color is a light green.
