Page 1 of 9 123 ... LastLast
Results 1 to 10 of 81
Thread: 1970 911T Light Weight Build
    Senior Member CaryPhotography's Avatar
    Mar 2012
    Thousand Oaks
    1970 911T Lightweight Build
    Day One
    After a month long debat about what to do about the engine, I seem to have been neglecting to rest of the "T". So, today was all about gutting the carpet, seats, pedal boards, and what ever else lives inside of the "T". Mind you, it's been resting in either a storage unit or garage for the past 20yrs and who knows what rodent has claimed stake inside. At the moment, the proposed end goal for the project calls for a completely gutted interior with little to no creature comforts.
    It's amazing what you'll find under the seats.
    Original color is Brown
    Good bye stereo
    Anyone know the best way to remove the wet and dried up glue residue?
    Who's interested in an original passenger seat w/ headrest?
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Grease and wax remover works well at getting most glue residue off.
    If you are going to put retractable seat belts in the car can i have one of the little black plastic hangers i can see on the 1/4 panel covering??
    Mar 2012
    Thousand Oaks
    Quote Originally Posted by classic View Post
    What about paint stripper, especially considering the fact that I'm planning on painting the interior.
    From what I hear, the main issue with paint stripper is that it will get into the little nooks and crannies like between the spot welds and then after paint it will result in fish eyes.
    working with any type of solvent inside the car is not very health. Some of those citrus cleaners are pretty aggressive and can get that glue off.
    Nov 2004
    Gold Coast.
    No paint stripper, as above and you won't be able to nutrilize it, as most require water.
    If you are going to remove the paint from the interior without media blasting, you basically only have one option and that's mechanical (wire wheel, sander ect.) JMO
    Mar 2012
    Thousand Oaks
    I'm caging the car and will not be reinstalling retractable seat belts. PM me your mailing address.
    Mar 2012
    Thousand Oaks
    I've already started to use the grinding wheel but I'd prefer to use some sort of solvent.
    got any suggestions on aggressive citrus based solvents?
    Senior Member ghost1001's Avatar
    Apr 2011
    West Caldwell NJ
    It’s a tedious job, but worth it.
    I tried solvents for the glue and that juts made a mess that had to be stripped with the wire wheel and stripping pads anyway.
    Assorted types of wire wheels on the grinder work well they dull down and loose wires while stripping the wires then shoot out and stick in any exposed skin, fun!!
    I bought a cheap set of coveralls from home depot and used a grinding face mask and dust respirator, gloves, etc.
    I would say it took about 20-24 hours of work to get the entire inside down to metal; it left a very nice surface for paint and was worth the effort.
    Here’s some inspiration to keep you going…(this is my ’76 turbo)
    Kevin
    Attachment 215196
    Member #2239
    '76 911 turbo lightweight
    '87 land rover D110
    Mar 2012
    Thousand Oaks
    Kevin,
    That is awesome!! Did you find that a wire wheel worked better then a high grit pad?
  1. For Sale - Light Weight Tail Light Housings
    By CamBiscuit in forum Australia
    Last Post: 02-06-2012, 09:17 PM
  2. FS 1970 911T Interior light
    By jwoods in forum For Sale: 911 Parts
    Last Post: 08-18-2011, 12:41 PM
  3. Light weight motor
    By Dave Mitchell in forum Technical Info
    Last Post: 09-17-2008, 02:41 PM
