Results 1 to 8 of 8
Thread: engine number T or S? Do they match the car?
    I have a 73t car and I'm trying to find out if the engine is original to the car.
    I'm also trying to determine if it's a T , E or S engine.
    The car was converted to Weber's in 1977 by PMO in San Monica . I have the paperwork from 77.
    There is a sticker that says the engine number which matches the block that says "2.4S". (maybe this was wishful thinking? In 1977) The sticker is from PMO when they converted to carbs.
    The build date of the car is 09-72 car number 9113100416.
    Does anyone here know if this engine matches the car before I get a COA?
    Thanks!
    Aug 2006
    Chicago area
    Look to the right side of the fan housing. There is a vertical flat portion of the casting down towards the block. It will have a seven digit number stamped there with 'stars' on either side of the number. It will start with the number 61xxxxx if it is a T engine. 63xxxxx if an S engine. Post what that number is and we can help you ID what you have.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    The number is 6130690,
    Also the number on the top of the fan housing is 901 106101 5R
    Jul 2010
    Bordeaux
    it's a 73 T engine ... last serial is fan housing ref
    Any idea if this could the original block for this car?
    Or would I only be able to find out with a COA?
    Also is the 61"3" designate a 73?
    Aug 2006
    Chicago area
    Quote Originally Posted by menmojo View Post
    Yes on the COA, but I have heard stories of gross inconsistencies in those documents.
    Yes, the 3 designates a 73MY engine.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Feb 2012
    Edmonton
    Engine#
    6 = 6 cylinder
    1 = T - fuel injected
    3 = 1973
    0690 = sequential number
    NOTE: USA/CAN 1973 T sequential numbers 0XXX = MFI injection, 3XXX = CIS injection
    VIN #
    911 = vehicle model (911)
    3 = model year (1973)
    1 = engine type (T - fuel injected)
    0 = body version (Coupe)
    0416 = sequential number
    It is most likely the original engine, the engine number is the correct age and type for your VIN.
    Excellent information.
    Thanks for all the input!
  1. No engine number??
    By ccporsche in forum Other Porsche Passions
    Last Post: 06-03-2013, 06:26 AM
  2. Replies: 2
    Last Post: 01-27-2011, 06:22 PM
  3. Engine / VIN match (1967)?
    By Eminence Gris in forum Technical Info
    Last Post: 06-10-2009, 08:03 PM
  4. Engine Number
    By mwilson3003 in forum Technical Info
    Last Post: 08-03-2007, 01:29 PM
  5. Engine number
    By hdavis in forum General Info
    Last Post: 03-11-2004, 08:16 AM
