Thread: Hard cranking windows
    Mar 2012
    Mishawaka, Indiana
    Is there any standard maintenance procedure for hard cranking windows?
    Larry Dunville
    • 1968 911S Targa Softwindow
    • 2002 996 Carrera
    S Registry Member #2247
    Check your tracks. If the felt is worn out you are running glass on rubber. Also check to see that the windows are not cocking to one side or the other.
    You can lubricate the rubber track with a silicone spray that dries and leaves some lubricity behind.
    Good luck!
    Tom
    Early S Registry #235
    rgruppe #111
    Jan 2011
    DFW TX
    I had my door panels off to replace the plastic and lubed the regulator mechanism, sliders and pivots. Made a huge difference in winding ease. Door lock mechanisms and check straps deserve attention too.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    While you're in there check your pivots and springs.
    and check that your drain holes in the doors are clear and any rust spots before they get going.
    Could someone please explain why, when using the replacement Stoddard hard channel fore,aft and top, the windows are really hard to crank in a SWB? The Factory successfully used hard channel fore, aft and top in the 356 and the SWB cars and the windows wound effortlessly. I use only a thin coat of rubber cement to hold them in place. And at $50+ a channel, I would love to know what the problem is.
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
  1. Replies: 3
    Last Post: 10-08-2013, 10:09 AM
  2. Replies: 0
    Last Post: 10-07-2013, 04:23 PM
  3. 911 1969 Sportsmatic not cranking the engine
    By boofs in forum Technical Info
    Last Post: 09-18-2012, 03:01 PM
  4. Help 911 not cranking
    Last Post: 09-07-2012, 04:22 PM
  5. WTT: tinted fixed side windows for tinted vented side windows
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 12-15-2006, 11:40 AM
