Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: FS- NOS 911R intake manifolds
    These are the real deal, never been on a car. $2800.
    Hello Craig,
    I would like to buy these if they are still available.
    I pm'd you for the details.
    With kind regards,
    Chris Mulder
    Edit, just recieved your pm. I will send you a shipping quote.
    Also, just to be clear. There is a section on each runner flange that seems to be chipped or ground away. It's on the outer flange and does not effect the function of the manifolds but it is worth noting. No surprises here. Not sure why this was done or if it was a casting flaw, never really bothered me....it's not like I could just grab another set The flange is absolutely not cracked, I have seen these crack from over tightening and that is not the case. It is very obvious that there has never been a nut/washer on the flange.
    Banned
    Nov 2004
    Scottsdale, AZ
    MFI injector notches.
    Hi Craig, If they still available let me know, I would take them. Thanks.
    Early 911s Registry # 2049
    '73 Carrera RS Touring, # 1346
    '89 Carrera Club Sport, white
    '91 Carrera RS, white
    2010 997 GT3 RS MK2, slate grey
    Banned
    Nov 2004
    Scottsdale, AZ
    Just to be clear: Someone may have intended to install these on MFI heads. The notches would be to clear the injector block-off plugs.
    No doubt. +1
    Early S Registry #235
    rgruppe #111
    Yes, good thinking Frank. Just to be clear, the flange is not cracked or damaged in any way. These will function perfectly.
    May 2005
    Southern California
    Below are a couple of photos; the first are my 911R Mag Tall Intakes, but for a normally aspirated engine, no notches. The second photo are the same Tall Mag Intakes, but for my 906 engine, also normally aspirated and also no notches.
    Note the differences between these two intakes and how their linkage assembly is installed. One obviously being a mid-engine...
    By the way Craig, your 911R intakes are beautiful...
  1. FS: 911R intake manifolds for Webers Genuine Mag real deal
    By VintageExcellen in forum For Sale: 911 Parts
    Last Post: 06-30-2013, 11:30 AM
  2. FS Original Factory Magnesium 911R ,906 Intake manifolds
    By budge96 in forum For Sale: 911 Parts
    Last Post: 10-02-2012, 06:46 AM
  3. 66 Intake Manifolds
    By jbell959 in forum For Sale: 911 Parts
    Last Post: 09-19-2010, 03:04 PM
  4. Porsche 911R Weber 46 & Intake Manifolds
    By 72targa in forum For Sale: 911 Parts
    Last Post: 08-24-2010, 08:11 AM
  5. 906 Mag Intake Manifolds
    Last Post: 03-06-2010, 02:35 PM
