Results 1 to 10 of 14
Thread: Fuchs refinishing
    Feb 2010
    Roseburg,OR
    Fuchs refinishing
    This one's for Harvey Weidman!(sent you a pm too)
    Any possible way to return these to their former glory?Name:  IMG_1418.jpg
Size:  146.8 KBName:  IMG_1422.jpg
    I would like to return them what a stock 73 wheel would look like. Does the chroming process prevent resurrecting these wheels?
    I have a pair of 6s and 7s
    Appreciate any and all input
    Chris J
    old softie67S
    Feb 2007
    Sanibel Fl
    Harvey is thr right person to answer this, but chroming Fuchs is not good for the metalurgy. The alloy becomes more brittle. Stripping the crhome does not reverse the effects of the original chroming.
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    +1 on Harvey.
    It looks like those are 16's and in 6" and 7" widths they are easy to find and cheap to buy.
    It might be better to start with a nice, stock, clean set and then have Harvey work his magic.
    Todd
    '71T 3.2 Spec 911 #806
    '69 BMW E9 Coupe
    Feb 2010
    Roseburg,OR
    Good point.
    Chris
    Feb 2010
    San Francisco, CA
    +1 to all of the above. If these are 16" wheels, I'd sell them off and look for a better set to resto. From what I recall on my visit out to drop off wheels with Harvey, he can in fact re-heat treat the wheels to get them non-brittle (I may be remembering this wrong though). I'm thinking it's probably not with it for these particular wheels unless you have an attachment to them.
    E911SR & RGRUPPE
    '73 S Coupe #306
    May 2005
    Oroville, CA
    Yes we can fix them....if the corrosion isn't too deep. Tom is right about the metalurgy. After removing the chrome we "reheat-treat" the alloy. It is actually called normalizing, but it is easier understood when described as ferrous metal terms.. It is usually worth at least dechroming the wheels to see what is left. Fornunately, you wheels can be readily replaced. Not like some others that come in for the same process. Most chrome shops will do a poor job dechroming. I have only seen a few shops do a good job and they aren't thrilled to do it again.
    H
    Feb 2010
    Roseburg,OR
    I would like to send them your way then. We'll see what can be done.
    THanks to all
    Chris
    Oct 2010
    Florida
    If you guys keep sending Harvey all these wheels he's never going to get to my Minilites. Gezzzzzzzz.
    Richard Newton
    Newton's Law
    Feb 2010
    Roseburg,OR
    I took all the above advice and ultimately sold off the red/chrome wheels and purchased a set of polished wheels.
    These are in pretty good condition and will work fine until I decide on the refinish for the stock black wheels
    Chris
    Feb 2010
    San Francisco, CA
    Well done! They look good too. I have a feeling that you've saved yourself a lot of headache.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. Fuchs wheel refinishing
    By caproader in forum Technical Info
    Last Post: 02-10-2016, 02:56 PM
  2. FS: Assorted early 15 X 6" Fuchs -- all need refinishing
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 11-02-2013, 09:42 PM
  3. Fuchs Refinishing
    Last Post: 11-06-2009, 09:11 AM
  4. FS: Set of 8x15 and 9x15 Fuchs wheels, ready for refinishing
    By Kaefer in forum For Sale: 911 Parts
    Last Post: 07-31-2009, 05:23 AM
  5. Fuchs refinishing...
    By Chuck Miller in forum General Info
    Last Post: 10-23-2004, 05:27 AM
