Results 1 to 7 of 7
Thread: FS: Old school solid Momo hub for early 911
    I've got a solid Momo adapter for early cars up to 7/73 for sale. I've had a few of these in the past and while some have said Momo, this one does not have any id stampings, just cast aluminum with a black wrinkle finish.
    It looks cleaner than the rubber accordian covered ones that are currently available. These are getting kind of rare and definately add an old school look to your Momo setup.
    Looking for $195 incl shipping to US or Canada
    Regards,
    Andrew M
    I'll take. PM sent.
    - Brian
    1966 Mercedes 250SE Cab
    Hi Brian - I just checked and it looks like a Nardi hub pattern - not Momo
    The Nardi is 6 bolt, but slightly larger in diameter.
    This could be offset a bit and redrilled for a Momo wheel if you still wanted it.
    price reduced to $175
    Regards,
    Andrew M
    If it fits my Nardi, I'll take it, PM sent
    Jeff Eelkema
    69E (project)
    S Reg #1431
    Aust TYP 901 #132
    Pisser. I'm out.
    - Brian
    Sorry Brain - I just double checked with my Nardi wheel and it matches up perfectly with that one.
    Jeff - Sending PM
    AM
    Dec 2010
    Tulsa
    Jeff, that''s an early Racemark hub - the pattern is Nardi/Personal, and will fit without issues, except that it uses one size larger bolts to mount the wheel. If you're using a normal Nardi that has a trim ring, you'll need to find the larger bolts with the same size head to mount the ring.
  1. Early Momo solid hubs
    By andyjboy in forum Technical Info
    Last Post: 12-29-2019, 09:27 AM
  2. Replies: 4
    Last Post: 03-11-2014, 03:28 PM
  3. FS: Nardi NOS steering wheel solid hub for early 911s (also for MoMo)
    By 911 SWTARGA in forum For Sale: 911 Parts
    Last Post: 02-05-2014, 08:14 AM
  4. FS: Early Flat MOMO Prototipo and solid hub
    By 70SATMan in forum For Sale: 911 Parts
    Last Post: 05-21-2012, 06:04 AM
  5. Early Momo solid adapter
    By tfiv in forum For Sale: 911 Parts
    Last Post: 09-23-2010, 03:58 PM
