Results 1 to 7 of 7
Thread: Motometer pressure gauge rebuild
    Jul 2003
    Santa Cruz, CA
    Does anyone have experience in rebuilding Motometer tire pressure gauges?
    I have a line on one but, appears that the internal seal might be dry. Can they be replaced?
    Not talking about the red bakelight types....
    This type is what I'm looking at...
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Feb 2008
    Santa Paula CA
    Hi Michael - Funny, I have the same gauge, though with a deflation protrusion on top of the opening, and Kg/cm2 in place of the bar label. Purchased in Austria back when as I recall. Always thought it more precise than the bakelight in the tool kit. Still gets regular use and works fine, so can't offer any advice. Hope the lights are coming along.
    -Richard
    1968 912 Sunroof, Irish Green (original owner)
    1985 911, Prussian Blue (sold)
    2010 Carrera 4S, Porsche Racing Green
    Feb 2010
    San Francisco, CA
    I've got the same gauge with what sounds like the same dry seal. I was going to try to dig out the old one with a dental pick and then hunt for a suitable o-ring @ the hardware store. I'll let you know if it works for me.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by rpidduck View Post
    -Richard
    There has been progress and I forgot to send those pics didn't I... I'll shoot you an email...
    I do like these better. They look sturdier and have the pressure hold function. Always preferred these to the ones supplied in the early kits myself as well.
    I'm trying to avoid buying something I'm not going to be able to use.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by kentf14 View Post
    Kent
    Kent, how accurate is yours? Does anyone know if they can be adjusted for accuracy?
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Jul 2010
    Bordeaux
    May be late but I opened mine yesterday to fix reset of the needle and clean repaint. Here's how it look inside and don't think accuracy can be adjusted.
    piston push the white part that rotate needle axes.
    Name:  2012-10-06 18.46.21.jpg
    Jun 2012
    London, Ontario, Canada
    They can be adjusted if you are adventuresome. You can add tension to the spring by bending the piece that goes into the rectangular arc towards the platic or remove sension by bending toward the open part of the arc. Obviously you need a reference gauge to know what is "corrrect". Correctnes varies with temperature for anything with a coil spring, aso thats the limitation.
    Ravi
    Early 911S Registry # 2395
  1. FS: Motometer tire pressure gauge
    By fourteenten in forum For Sale: 911 Parts
    Last Post: 10-20-2013, 01:49 AM
  2. FS: MotoMeter NOS Outside Temperature Gauge
    By Nordschleife in forum For Sale: 911 Parts
    Last Post: 05-27-2009, 03:59 PM
  3. MotoMeter Air Gauge
    By Bobby Smith in forum General Info
    Last Post: 03-31-2009, 08:24 AM
  4. Repair to motometer tire pressure gauge
    By denson in forum General Info
    Last Post: 12-06-2008, 07:49 AM
  5. Motometer tire pressure gauge
    By preS in forum General Info
    Last Post: 07-19-2005, 06:00 PM
