Thread: heip! earley master brake from single to duel
    early 911 single master to duel brake light switch
    i have a late model duel master cylinder on an early car is there a brake light switch available for this conversion or do i need to convert to banjo bolt and volks wagon style switch
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    The later style has a brake light switch that mounts to the pedal cluster.
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    dual circuit cylinder in early car
    I used a BMW reservoir modified to mount in the original location because it has the partition inside to separate the fluid between front and rear circuits. I also used the original pressure switch by installing another banjo at the master cylinder. Later picture shows the plastic spacer used on the reservoir bracket screw.
    The mechanical brake light switch doesn't mount on the 67 and earlier pedal clusters.
  1. FS ’65-’67 911/912 Single Circuit Master Cylinder-NEW
    By 68911+1 in forum For Sale: 911 Parts
    Last Post: 03-17-2010, 09:31 AM
  2. Dual single-circuit master cylinders
    By 40cylinders in forum Technical Info
    Last Post: 02-17-2009, 07:21 PM
  3. Conversion from Single to Dual Circuit Master Pump...
    By SprintStar in forum Technical Info
    Last Post: 08-09-2003, 09:06 AM
  4. Brake master cylinder
    By herrongrey66 in forum Technical Info
    Last Post: 09-12-2002, 11:54 PM
