Results 1 to 10 of 11
Thread: cam nut tool from hell
    Sep 2008
    Auckland , New Zealand
    After a weekend of trying to get cam nuts off with the useless crows foot ( man i hate that tool ) and almost loosing my rag over it I decided to make the mother of all came nut tool removal devices, so this bad boy is the result .... and man does it kick ass
    .Name:  IMG_20120531_161244.jpg
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    That`s impressive!
    Quote Originally Posted by advtracing View Post
    Of the poor bastard who has to pick it up!
    Well done!
    Tom
    Early S Registry #235
    rgruppe #111
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    And who says size doesn't matter..... I like it
    Does it double as a propeller.
    Senior Member Christian Guthrie's Avatar
    Jun 2011
    Arizona
    Reminds me of one of my favorite movie lines. " now reach into that bag and give me back my wallet. It says bad mother $@?!&! on it! "
    Sep 2008
    Well there is down side , using the porsche cam socket on the short bar I put so much pressure in it I oval'ized the socket ... lucky I have two
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Feb 2011
    Surrey, UK
    Hello John,
    Can you pass on a few details as to how you made it and what from - apart from a piece of thick tubing and two sodding great iron bars!!
    Might want to build version 2 sometime soon.
    .... or is the patent already filed....?
    I just love homemade engineering solutions.
    Mick
    Restoration newbie.
    Jun 2007
    San Francisco
    Great for taking off, but how do you put a torque wrench onto it?
    Perhaps v2 could have a half inch square drive welded on as centrally as possible.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Sep 2008
    Hi guys , I only made this one for getting the nuts off as the crows foot is just OK for retorquing .
    The tool is easy , just went to the second hand engineering tool shop , found a 46mm socket , cut the top off so it,s just a cylinder with no taper, put a 30deg edge on the top , cut a piece of solid 5mm wall tube , add a 30 degree edge to that , weld the two together using high level on the welder to get good penetration and fill the v this makes the main section 75mm high , and the rest you can see.
    I added the two handles as this allows the socket to be pushed flat over the nut and not cause a slight angle which could damage the nut if you slip . I have always found that with only one long handle you can never be sure your dead straight or flat.
    The lot cost 20 bucks to make
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  1. Porsche Hell
    By LongRanger in forum Other Porsche Passions
    Last Post: 08-06-2014, 04:47 PM
  2. More Porsche Hell . . .
    Last Post: 11-15-2011, 02:35 PM
  3. Why the hell not?
    By 69Sman in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-14-2006, 03:35 PM
  4. What the hell is the deal with Palo Speedo?
    By RPMClassic in forum General Info
    Last Post: 08-31-2004, 03:42 PM
  5. What the hell happened?
    By rst73 in forum General Info
    Last Post: 06-30-2004, 09:25 AM
