Results 1 to 8 of 8
Thread: Cast iron cylinders in a '65 911?
    Oct 2005
    Minneapolis, MN
    Just trying to verify that a 1965 911 originally had cast iron cylinders....the rusty ones?....
    Thanks!
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    65 had Biral which is aluminum fins around a cast iron liner
    if they are rusty on the outside they are 68- 911T
    Oct 2005
    Minneapolis, MN
    I think these were replacements. The pistons don't have the oil ring below the wrist pin either....but are not some aftermarket forged jobs...
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Senior Member E911's Avatar
    Dec 2011
    Frozen Tundra
    so what would the correct pistons look like for a 65?
    Oct 2005
    Minneapolis, MN
    Wondering...all the 2.0L pistons I've seen had the oil ring below the wrist pin. But I'm not sure if they were always that way.
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Aaron do you still need 3 hole rods ? I have 5
    Jeff H.
    72 911
    914-6 GT
    Oct 2005
    Minneapolis, MN
    Quote Originally Posted by JKH View Post
    Yeah...maybe, let me get back to you. Thanks Jeff!
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Ring placement
    Aaron, The 911S had all three lands above the wrist pin, and also had the larger/deeper valve pockets.
    The normal pistons had the ring lands two up and one below the wrist pin.
    Let me know if you need any Mahle singles with the Biral cylinders.
    Bob
    Early S Reg #370
  1. FS: Cast iron 84mm cylinders, 2.2T pistons
    By DG58INNM in forum For Sale: 911 Parts
    Last Post: 12-28-2012, 06:07 AM
  2. WTB: 2.0L cast iron cylinders and 3 hole rods...
    By Flat Six, inc. in forum For Sale: 911 Parts
    Last Post: 05-11-2012, 07:03 AM
  3. FS 2.0 heads and 2.0 cast iron cylinders
    By byron in forum For Sale: 911 Parts
    Last Post: 05-16-2008, 10:38 PM
  4. boring 2.2L cast iron T cylinders
    By timothfarrar in forum Technical Info
    Last Post: 05-03-2003, 09:17 AM
