Thread: 915 Oil Pump gasket question
    Jan 2006
    Naperville, IL
    In the PET two gasket part numbers are shown for the oil pump cover on the rear of the 915 transaxle. One is .015mm thick and the other is .02mm. Is this used for setting a thrust clearance for the pump gears? If so how is this best measured.
    P/n Ref#9 in photo
    915.307.311.00-.015mm gasket
    915.307.311.01-.02mm gasket
    Thank you,
    Andrew
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Aug 2007
    Phila Pa. area
    adjustment
    They are used to set the end play, which should be .05mm. There is a section in the factory 915 gearbox manual which shows the procedure.
    Mike Curnow
    Mike
    I use a dial indicator on the end of the drive shaft after the pump cover is test installed. gled
    Jan 2006
    Naperville, IL
    Thank you Mike/Gled;
    When you check this you have the end/tail cover removed and check it from the "inside", correct? I had purchaed a gasket set and was hoping to order this last gasket from the dealer before tearing into the transaxle. I did read through the 72+ manual and did find a section talking about these gaskets but the main instruction was to measure the old gasket...I did and it did not match either gasket thickness above (due to being compressed?). Is just one gasket used or is it plausable that one would stack them to get the proper endplay?
    Thanks again,
    Andrew
    -Andrew
    '72 911E
    S Reg #1074
    Aug 2007
    Phila Pa. area
    Stack them, thats why there are two different thickness.
    Mike
  1. twin fuel pump question
    Last Post: 12-12-2021, 04:05 PM
  2. WTB: MFI Pump Gasket Set
    By gruen911 in forum For Sale: 911 Parts
    Last Post: 12-18-2012, 11:54 AM
  3. Bosch Fuel Pump Question
    By 72Group4 in forum Technical Info
    Last Post: 10-03-2011, 10:45 AM
  4. Fuel Pump/pressure Question
    By garycox in forum Technical Info
    Last Post: 09-08-2009, 04:41 AM
  5. MFI pump question
    By Alan.uk in forum Technical Info
    Last Post: 03-16-2007, 09:57 AM
