Results 1 to 9 of 9
Thread: 911 s 2,4l
    911 s 2,4l
    Hello Folks,`
    I am looking to buy a 2,4L S, I was checking the numbers, VIN is OK but I cannot find the engine number on my books, can you help ??
    N° is 6273545 !!
    Jan 2011
    DFW TX
    That is a 1977 US 2.7 liter.
    May 2009
    West LA
    Quote Originally Posted by froggy View Post
    Hello Folks,`
    N° is 6273545 !!
    There are a couple of 2.4S engines in the lost and found. What's the VIN on the car that caught your eye?
    -Dave
    Registry Member #1583
    Quote Originally Posted by popowitz View Post
    -Dave
    Here are the numbers, 911 S Targa
    Chassis 91133103391
    Engine 6273545
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    Your chassis nr is not correct. It has onedigit to many. should it be 0391 at the end?
    Check this site for some number ranges: http://www.elferhelfer.de/fzident.htm#
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    Jan 2011
    DFW TX
    The number of digits is correct for a vin... its just that the Serial number range didn't go that high for an S Targa. Are you sure its an S and that the 5th digit is a 3 and not a 1 for a US T?
    Oops, I'm wrong... should be ten digits total. But the last 4 can't be 3391 unless its a T!
    Feb 2010
    San Francisco, CA
    Quote Originally Posted by M_deJong View Post
    The number of digits is correct for a vin... its just that the serial number range didn't go that high for an S Targa. Are you sure its an S and that the 5th digit is a 3 and not a 1 for a US T?
    Are you sure about that? A '73S Targa should be something like:
    911331XXXX
    91133103391 has one too many digits.. or am I wrong?
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Senior Member vipergruen's Avatar
    Feb 2007
    Milan, Italy
    Any 1970MY-on 911 has a 10 digit VIN, so 91133103391 has one too many.
    Andrea
    Andrea
    Early S registry #1082
    Jan 2011
    DFW TX
    No, its me... and I thought I was good with numbers!
