Results 1 to 7 of 7
Thread: Engine help
    Jul 2010
    Toronto
    Engine help
    I have just picked up a car and the motor was built by the PO as outlined below.
    911/91 2.4 ltr case
    2.2 S pistons
    2.2 S heads
    E cams
    carbs 40IDT webbers redone by Harry Beiker
    Does anyone have any opinions on the build.
    Engine seems to run a little rough right now but the valves need to be adjusted after the break-in period.
    What would the estimate on hp and will the engine run ok as built?
    Thanks Gerry
    Is your crank a 2.4 (70.4) or 2.2 (66).
    Search for a thread by Dr 911E. He posted the dyno information of his 2.2 w/ 70.4 crank (and 2.2S heads)
    Richard
    Jul 2010
    Toronto
    2.4 I was told.
    Thanks I will check the thread.
    May 2005
    Oroville, CA
    My engine:
    2.4 crank
    2.2S pistons
    2.4T heads
    S cams
    Webers
    188 RWHP 7100
    A little fat;
    Needing a jetting for +
    H
    Jul 2010
    Toronto
    Engine in question
    I have been corrected by the PO
    2.4 case
    2.2E pistons & cylinders
    2.2S heads
    2.2 E cams
    what do you think now?
    Sounds like a well rounded street engine that should make you smile.
    Tom
    Early S Registry #235
    rgruppe #111
    Hi Gerry
    Have a look at this thread, should have some info for you.
    http://www.early911sregistry.org/for...e+engine+build
    Kind Regards
    John #1022
    1970 911E 2.2
  1. Replies: 8
    Last Post: 09-01-2012, 05:47 PM
  2. Fleebay Engine: 1968 Porsche 911S Engine 901/02 Weber IDS 40 Carbs 911 S Motor
    By Doc72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 08-31-2012, 07:09 AM
  3. Replies: 23
    Last Post: 08-30-2012, 06:01 PM
  5. Replies: 33
    Last Post: 11-02-2005, 03:13 PM
