Thread: Measurements for placement of badge on engine decklid - 73 911S
    Intern 2nd Class
    Dec 2010
    Singapore and California
    Couldn't find it in the archives, but can anyone send me the factory-placed measurement of the model badge from the grill opening to the top of the badge?
    Thanks in advance!
    73 911S Targa #432
    14 911 50th Anniversary #1323
    How about a real measurement? I aligned the tape with the flat surface that is 90 degrees to the engine lid. (the part that is turned down) then measured to the top of the "911S" on my 73S and it is 39MM
    Feb 2010
    San Francisco, CA
    Same here. Using the same points to measure, 4cm.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Intern 2nd Class
    Dec 2010
    Thanks a million. Measured it out to 39mm as ret9191 said, leveled it up and marked the holes. Was worried because my decklid is aluminum. Went to drill with a carbide bit and it cut through like butter... apparently the holes were already there just bondo'd over!
    73 911S Targa #432
  1. Q: placement of engine decals on 67 911S
    By Anthony67_911s in forum Technical Info
    Last Post: 10-07-2014, 11:10 AM
  2. Badge Placement for 66 rear trunk deck
    By luke-44 in forum Technical Info
    Last Post: 11-09-2013, 07:38 PM
  3. Duck Tail script placement & measurements?
    By QWKENF-911 in forum Technical Info
    Last Post: 09-16-2012, 09:09 PM
  4. WTB: 2.4 decklid badge
    By geneulm in forum For Sale: 911 Parts
    Last Post: 08-16-2012, 12:26 PM
  5. need quick measurement for "911" decklid placement
    By bob tilton in forum General Info
    Last Post: 12-10-2003, 09:56 PM
