Thread: Rear shock mounting bolt
    Junior Member
    Apr 2012
    San Diego, CA
    Is the lower rear shock mounting bolt and nut on a 70 911 plated and if so is it gold zinc.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    My 69 was gold, with no black evident.
    Tony
    Senior Member Orbit's Avatar
    Oct 2010
    Jupiter , Florida
    I just removed this right rear shock bolt from my 70 T Targa. Not easy to prove that it was yellow cadmium plated originally but it does seem there is some "gold" color in the root of the threads. The markings on the bolt are KAMEX 8.8 . Interesting to look at the detail of the split lock nut, also note that the smaller washer was between the shock and the trailing arm. The nut on the back side of the trailing arm did not have a washer. I will have to look at my parts manual tonight to confirm. Bigger question is what do you do with a bolt that looks like this? How do you properly prep it for plating and which process to go with - Cadmium plating or the zinc plating with the yellow wash ( phospate?) ?
    Yellow zinc, both bolt and unique split nut.Name:  L1030309.jpg
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
  1. 901 Mounting Bolt
    By 50/50 in forum Technical Info
    Last Post: 07-22-2013, 01:02 PM
  2. 901 trans mounting bolt
    Last Post: 07-01-2013, 02:47 PM
  3. Aluminum rear lid (shock)
    Last Post: 03-03-2012, 10:15 AM
  4. Rear shock, lower mounting rubber?
    Last Post: 05-27-2010, 01:32 PM
  5. Lost a lower shock absorber bolt
    By pgxif in forum Technical Info
    Last Post: 08-21-2004, 01:04 AM
