Results 1 to 10 of 13
Thread: Different Rear Swing Arms - which is correct for a '69 car
    Senior Member Andy B's Avatar
    Feb 2005
    Near Bondi Beach, Sydney Australia
    OK, today I was with my mechanic and he's found I have two different rear swing arms (trailing arms) on my '69 911E race car.
    Looking at the photos, the difference is in the last end part of the leg, the conical shaped bit that attaches to the shock.
    I suspect one is original and one is not. Question is which is which ??
    Second question , who's got one ??
    Thanks for any help.
    First photo is LHSIMG_0395.jpgIMG_0396.jpg and second is RHS.
    Andrew B (Tiger)
    911 69E Historic Production Race Car
    Port Macquarie, Australia
    Looks like the left one has been modified or repaired? It's definitely the odd one.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Andy, I've done some surfing... http://www.early911sregistry.org/for...ght=banana+arm post #6 Looks like you hava a 71-2 arm and a correct 69. Not sure how different the geometry is... I suspect none?
    John Forcier
    EarlyS #1987
    Restoration Saga
    Feb 2005
    John and Ryan thanks
    I'll send MN a copy of this photo of a 72-72 arm and get him to check RC's car as it is a '69 too.
    Next problem is to find one .....
    Andrew B (Tiger)
    andy
    autowerks have the original arms from the 12/69 built car i have if that helps ?
    Craig
    Newcastle, Australia
    ESR #1479
    1973 2.4E Coupe ex Hong Kong ex Norfolk Island ex New Zealand now in Oz
    (Autowerks restored stunner)
    http://www.autowerks.com.au/porsche_projects/index.html
    1972 2.4E Targa ex Germany ex Japan now in Oz
    (another Autowerks project)
    1969 built E based Vintage Racer
    (another Autowerks beauty)
    http://s12.photobucket.com/?postlogin=true
    ^^^^ That's what you need Andy
    I now suspect the geometry could be different... the later versions mounted the shock strut in combination with the different cross member above which has different (bigger) apertures. This is the issue when you fit later alloy arms to the older chassis.
    John Forcier
    EarlyS #1987
    Restoration Saga
    I can't believe you have been running one cheater arm all this time.
    The depths to which people will sink...
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    I'm outraged
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Feb 2005
    Melbourne, Australia
    Cool
    Perhaps this explains Andy's great performances in the wet?
    He had a special 3 wheel steering early 911, with trick suspension! Smokey Yunick style (the fellow who scaled down a Nascar, because the rules did not forbid it).
    Feb 2005
    New arm coming !
    Now for all those other cheaters out there ..........
    Andrew B (Tiger)
  1. FS: Rear Banana Arms SWB
    By 68911+1 in forum For Sale: 911 Parts
    Last Post: 02-26-2013, 05:12 PM
  2. FS 930 rear arms
    By OliveR in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 08-11-2012, 01:01 AM
  3. '69 Trailing/Swing/Banana Arms - which is correct ??
    By Andy B in forum Technical Info
    Last Post: 07-01-2012, 07:22 PM
  4. FS: Aluminum swing arm set upgrade for '70-'73
    By budge96 in forum For Sale: 911 Parts
    Last Post: 06-10-2012, 07:05 PM
  5. New bushing necesary on my swing arms?
    Last Post: 09-10-2009, 05:38 AM
