Results 1 to 9 of 9
Thread: '69 Trailing/Swing/Banana Arms - which is correct ??
    Senior Member Andy B's Avatar
    Feb 2005
    Near Bondi Beach, Sydney Australia
    OK, today I was with my mechanic and he's found I have two different rear swing arms (trailing/banana arms) on my '69 911E race car.
    Looking at the photos, the difference is in the last end part of the leg, the conical shaped bit that attaches to the shock.
    I suspect one is original and one is not. Question is which is which ??
    Second question , who's got one ??
    Thanks for any help.
    Andrew
Size:  90.7 KBName:  IMG_0395.jpg
    Andrew B (Tiger)
    911 69E Historic Production Race Car
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Andrew,
    The top one looks like the one I have in my 69
    Tony
    The top one is the correct one for a 69. They moved the shock mount further back in 72ish and also modified the turrets in the cross member to accomodate the top of the shock.
    Kind Regards
    John #1022
    1970 911E 2.2
    Feb 2007
    Thousand Oaks, CA
    Yup, just checked mine . . . top picture looks correct for a 69E.
    Tom Ching
    69E Burgundy
    Aug 2007
    Phila Pa. area
    rear arm
    If you need one for a 1969, driver side I have one. It also has the factory sway bar knob
    I also have the factory tool to check it out.
    Mike
    Mike
    Feb 2005
    Thank you everyone, I think that's definite. Top photo is '69 and other is '72ish.
    When I was building my car I found that one front strut on the LHS was incorrect and didn't notice the rear difference. I also never knew there was a rear change from '69 to later models.
    It would seem that the car must have had an accident along the LHS and both suspension mounts front and rear were damaged and of course the wrong parts were fitted.
    Thanks again, what great resource !
    Andrew B (Tiger)
    Aug 2007
    Phila Pa. area
    swing arm
    Driver side arm, and the factory tool to check it for straightness. $175.00 for the arm.
    Mike
    Mike
    Aug 2007
    Phila Pa. area
    tool
    Forgot to post a picture of the tool
    Mike
    Mike
    Has anybody got the factory information to retro fit the sway bar ball pin to the trailing arms? I have the ball pin from porsche and want to fit them to my 1971 911. Has Porsche released these dimensions?
    Norbert.
  1. Swap steel trailing arms with alu trailing arms?
    Last Post: 10-16-2018, 02:37 AM
  2. WTB: LWB Banana Arms
    By Fubawu in forum For Sale: 911 Parts
    Last Post: 07-08-2013, 07:51 AM
  3. Replies: 12
    Last Post: 07-12-2012, 12:37 AM
  4. WTB: 'Banana' trailing arms for SWB
    By Don in forum For Sale: 911 Parts
    Last Post: 04-12-2011, 09:12 AM
  5. New bushing necesary on my swing arms?
    Last Post: 09-10-2009, 05:38 AM
