Thread: Dimensions needed for early 911
    Jun 2012
    London, Ontario, Canada
    Can somebody please tell me how high the fender is from the ground on stock tires (give or take) on a LWB 911 (mine is a 1973 911S) ? Also can you measure where the bottom edge of the windscreen starts from the front bumper or lip of the hood ? I'm trying to plan out a garage lift and every inch is precious.
    I'll look for a R&T summary page too, which might have those heights because they used to put cars up against a measurement grid once upon a time.
    thanks in advance
    NT
    Dec 2010
    Tulsa
    Look in the factory workshop manuals - theres a really nice dimensional layout.
    Jun 2012
    Are you referring to the one in section 8 ? I don't think it has all the info I need. But I did find an R&T test panel for a RSR, so that's good enough to plunk down my lift and garage door rails to check.
    The R&T test panel for the 1973 911S was right under my nose in another thread. http://www.early911sregistry.org/for...-Test-Articles
    Jan 2003
    UK
    How about this from the '72/'73 Technical Specifications booklet ?
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. Are these dimensions correct for a SWB car?
    By Bradford in forum Technical Info
    Last Post: 03-07-2014, 06:55 AM
  2. LWB dimensions needed
    By jhelgesen in forum Technical Info
    Last Post: 08-31-2011, 04:31 AM
  3. Battery Box Dimensions
    By joetiii in forum Technical Info
    Last Post: 04-11-2010, 06:36 AM
  4. Dash Speaker Grill Dimensions Needed
    By ibmiked in forum General Info
    Last Post: 02-09-2010, 05:37 PM
  5. 901 flywheel dimensions
    By tomkirkcis in forum Technical Info
    Last Post: 11-26-2009, 10:46 AM
