Results 1 to 7 of 7
Thread: 4 early matching 15x6 deep six Fuchs hearts with center caps
    4 matching 6Jx15 Fuchs. 3 dated 1/70 and 1 dated 10/68. All four wheels are part number 901.361.012.06. They are in original unrestored condition. Good shape-no major damage or curbing, etc. Just minor scratches on the center caps. $2200 for all four including center caps.
    PM Sent
    BB
    Bernd Buschen
    R Gruppe # 357
    71' 914-6 Original Owner
    70' 914-6 GT Stoddard Built
    69' 911E Scott's car
    70' 914-6 Sold
    These wheels are still available. Price drop to $1900
    You have a PM. Thanks
    I will take them if still available @ $1900..plus shipping/your location? email me @ swb911s@comcast.net
    ORE67S
    67 911S-SILVER
    65 356SC COUPE -SOLD
    73 914 2.0 YELLOW [74K]
    74 914 1.8 WHITE
    Kindly, I would like to ask if any of you have any idea where I can buy Air Valves or else the valves' part number for Fuchs Hearts Wheels (Part no. 90136101206) 6" x 15" deep. I would really appreciate your help, since I can't find any in my country (Malta). Thanks in advance.
    Thanks,Malcolm Farrugia.
    Hi MFP911,
    I posted this awhile back.....I'm not sure if you can find these in your country. If not I can probably track some down and ship them to you. Let me know how you make out.
    'My '67 runs on deep 6's with modern 195/60/15 tires without tubes with no problems. The only issue I ran into was dealing with the valve stems.
    If you're not going to run tubes you'll need to install larger / fatter valve stems to fit the stem holes on the Fuchs. The correct valve stem that will properly fit can be bought at NAPA.....the TR415. Not all TR415's will work.....only the ones in the Napa pre-pack work. The difference is in the profile of the base. The 6" Fuchs have such a thick rim, the valve stem cannot engage all the way through the hole and latch on the opposite side. The Napa TR415 is very square in profile which gives plenty of meat to securely capture the inside diameter of the hole. The other TR415's are tapered from top to bottom and would pop right back out of the hole.'
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    SOLD - 1967 911N / 1968 911L / 1967 911N / 1969 912 / 1991 964 C2 / 2013 991.1 / 2008 987 Cayman
  1. WTB: fuchs 15x6 center caps
    By LV911 in forum For Sale: 911 Parts
    Last Post: 05-25-2013, 04:41 AM
  2. Replies: 0
    Last Post: 07-03-2011, 07:16 PM
  3. FS: Fuchs Early Center Caps
    By jhora in forum For Sale: 911 Parts
    Last Post: 03-04-2009, 06:56 AM
  4. FS: 7X15 & 8X15 Gold Fuchs Wheels, Matching Center Caps
    By Carl Bauer in forum For Sale: 911 Parts
    Last Post: 12-03-2007, 07:46 PM
  5. Early Porsche 911 Fuchs Deep Six 15x6 Wheels w/ Hearts
    By 72targa in forum For Sale: 911 Parts
    Last Post: 12-01-2006, 03:35 PM
