I plan to install a dual zone m/c in my 65. Does anyone have any recommendations? Would any late 70's - early 80's Ate m/c work? Is there a difference between a m/c designed for a car with front disk - rear drum and a four wheel disk setup?
Your car would be a 4 wheel disc brake. A popular option is to use the dual circuit set-up from a '68-.
John Thompson
1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
Easy way out.
http://classicandspeedparts.com/inde...art&Itemid=140
Early S Registry #235
rgruppe #111
Use the parts from a 68 including the reservoir and clamp. Will Pringle's kit does not include a divided reservoir. Be sure to put a correct flare on the steel tubes that enter the MC.
By the part numbers:
901.355.013.00 Reservoir for master cylinder
901.355.927.00 Flexible hose for connecting reservoir to master cylinder
901.355.015.00 Mounting strap for reservoir
901.355.061.00 Hard line for connecting reservoir to master cylinder for front wheel portion of master cylinder
901.355.062.00 Hard line for connecting reservoir to master cylinder for rear wheel portion of master cylinder
901.355.012.00 Tandem Master cylinder
901.355.904.00 Metal seal 12 mm for banjo fitting
901.355.902.00 Metal seal 12 mm for banjo fitting
695.351.531.00 Banjo fitting
695.351.534.00 Hollow Banjo bolt
901.355.619.00 Left front brake line
901.355.620.00 Right front brake line
901.355.612.00 Brake line to rear brakes
901.355.615.00 Right angle connecting piece to rear brakes
(parts list courtesy of Panorama article from April 1985)
some may be NLA - but it will get you started.
Bob
Early S Reg #370
Of course you should thoroughly and completely test the installation to be certain the brakes are fully functional before moving the car.
Thanks for all the tips. It's a great list. I used a 68 Beetle m/c when I converted my 59 A coupe to dual zone. It stops well and straight (rare for a 356...) The cylinder fluid capacities for disk brake cars must be different than drum cars. The 356 has 2 cylinders per front wheel and one per rear. I'll take your advice and pick up a 68 911 m/c and start there. It will be sized properly. I used a dual chamber 911 reservoir that I picked up at Roundtop on the 59. I'll do the same on my 65. - Mark
