Thread: Aluminium crossmember SWB?
    Restoration newbie.
    Jun 2007
    San Francisco
    Is the later aluminium front cross member compatible with the 67 and earlier SWB front suspension?
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Aug 2009
    SF Bay Area
    Quote Originally Posted by ajwans View Post
    andy
    No, you are stuck with the steel one.
    Jim
    Hey Jim'
    I have a later aluminum cross member bolted right up to my '67S tub. I put it in just to put it on my shop dolly for stripping and paint. It doesn't have the the two struts ( I was going to call you for a pair) but it fit right up.
    Obviously, the early A arms won't fit in the aluminum receivers, but if one is going to a later A arm/ball joint/strut setup...doesn't the whole thing just bolt in.
    If the stock later aluminum struts don't line up, why wouldn't a little fab work make a fit???
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Aug 2009
    SF Bay Area
    Quote Originally Posted by smedley View Post
    Hey Jim'
    Hi Mark
    Yup, a complete suspension from any later car (1989 or earlier) will bolt right right in a SWB car. You can bolt a SWB control arm to an aluminum crossmember if you have a 1968 (which still uses the early ball joints), but nothing earlier. I don't think any amount of fab work will allow a 67 or earlier control arm to work with an aluminum crossmember. The 68 control arms are "one year only" and can be bought in a junk yard in the SF Bay Area for not a lot of money.
    Jim
    May 2005
    Oroville, CA
    Hi Mark
    Jim
    I only know of a fancy smanchy porsche auto recycler in Emeryville.
    H
  1. Rear suspension crossmember 901.501.075.21
    By Richsmith901 in forum Technical Info
    Last Post: 06-10-2013, 04:55 PM
  2. crossmember protective plate
    By plumber in forum Technical Info
    Last Post: 03-14-2013, 03:43 AM
  3. 912 trannie crossmember for sale
    By speedo in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 10-22-2011, 05:11 PM
