Thread: best way to remove paint from fan and housing
    Aug 2005
    VA
    I rebuilt my engine a year ago and just had the car painted. The engine looks like cra.....p because I painted the fan silver and the housing black a few years ago and it never really stuck (chipped very quickly). Should have had it all powder coated during the rebuild but did not.
    I want to take it back to original and strip the paint off. Is chemical paint striper a bad idea? This would make it a simple, couple hours project as I don't have a media blaster.
    Chris
    73 911 E
    Senior Member aporschaguy's Avatar
    Feb 2005
    Great White North
    I've both stripped with aircraft paint remover and used media blasting. Media blasting by far gives better results and can be done very cheap. I had my last fan and housing blasted by a local hot rod guy who had a smaller media blaster. He did it for 10. The paint stripper and elbow grease were allot more than that.
    "He has all the virtues I dislike and none of the vices I admire."
    1971 911e
    1978 911sc Targa (Sold)
    1973 911 RSR (Clone)
    Sep 2006
    La Quinta
    Paint stripper should be fine. I used it to take off powder coating on a fan.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Aug 2005
    VA
    Glad to know a basic paint stripper and some elbow grease is sufficient. Once it's stripped, just reinstall or should a clear or other protectant be used. I am prob. over thinking a simple project.
    Chris
    73 911 E
    Sep 2006
    La Quinta
    Chris,
    After you get it stripped, use "Gibs Brand" on it. I don't have the link, but it works great!
    Registry #983
    R Gruppe #741
    Feb 2010
    San Francisco, CA
    I also had good luck removing powder coating with media blasting. I followed this up with Gibbs. I wouldn't recommend clear or any other type of coating.
    Several Gibbs threads on the board.
    http://www.early911sregistry.org/for...ot-engine-fans
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. How do I remove my distributor?
    By PMNorris in forum Technical Info
    Last Post: 03-06-2014, 09:12 PM
  2. paint for restoring H1/H4/Euro housing ?
    By CarmelSkip in forum Technical Info
    Last Post: 04-03-2009, 06:31 PM
  3. How to remove A/C system?
    By berettafan in forum Technical Info
    Last Post: 11-09-2006, 10:09 AM
  4. How do you remove an SWB dash?
    By 304065 in forum Technical Info
    Last Post: 10-03-2006, 10:34 AM
  5. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
