Thread: Correct wiring for radio/auxilary
    Having recently spent some time under my dash I got to witness first hand some untidy wiring. At some point in time the car had an after market stereo and amplifier installed and the now correct radio is wired to the remenance of the previous install.
    Can somebody please advise what is the correct way to wire up the radio and where am I best off sourcing auxiliary power from for any aftermarket electronics (such as a charger for my iPhone)
    Cheers
    Dirk Janek
    1970 911T 3.0/915
    The radio power wire is a yellow wire in a plastic sleeve that that runs along the lip of the dash. Many aftermarket installers don't know its there so they end up mutilating the harness to get power. Often the end of the wire is tucked back into the sleeve and just needs to be pulled out. This wire will be switched with the ignition switch so the radio goes off with the ignition off. I suppose you could use a double connector from this wire to power your charger.
    Apr 2011
    N.Calif., south of SF
    Is there another source for power that utilizes the accessory position on the ignition switch?
    Correction: The yellow wire is switched to the accessory position on the ignition switch (or at least is is on my car)
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Atlanta, GA
    What's wrong with using the cig lighter for charging the cell phone?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  1. Radio Wiring
    By turbochad in forum Technical Info
    Last Post: 12-31-2021, 08:52 PM
  2. Correct wiring diagram for 70 T
    By 356robo in forum Technical Info
    Last Post: 07-03-2018, 03:42 PM
  3. Correct wiring to CD box, 73.5 CIS
    By caproader in forum Technical Info
    Last Post: 09-05-2009, 04:36 PM
  4. FS Marchal Auxilary lights
    By mikez in forum For Sale: 911 Parts
    Last Post: 06-15-2009, 04:38 PM
  5. Need help wiring my US Franfurt radio w/ shortwave
    By 911scfanatic in forum General Info
    Last Post: 04-23-2009, 06:17 PM
