Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
Thread: LED light bulbs
  1. #41
    Apr 2011
    N.Calif., south of SF
    I agree with the full 360 light dispersion- the interior of stock light housings reflect the light. The ones I used are like these
    This style reflects all around inside the housing.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  2. #42
    Jun 2012
    London, Ontario, Canada
    Quote Originally Posted by Haasman View Post
    I think that's the right approach in our cars, as opposed to my bike. I use the incandescent bulb set that John Audettte sells which are 50% brighter than stock and I think they are fine. More current draw than stock or an LED, but my alternator can handle it. I drive with lights on all the time.
    Early 911S Registry # 2395
  3. #43
    Feb 2010
    San Francisco, CA
    I also installed the Audette incandescent bulbs..mostly because I'm lazy and didn't want to deal with splicing in resistors etc. Brightness is moderately better than stock. Certainly not LED level, and if I could, I'd just pop LEDs into the brake lights as that's really what I want to grab attention.
    E911SR & RGRUPPE
    '73 S Coupe #306
  4. #44
    Apr 2011
    Especially the brake lights, the LED's are quite easy to install. No resistors, no special connections, just one bulb out, LED bulb in.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  5. #45
    Feb 2010
    San Francisco, CA
    Just ordered some brake lights. Should be a nice boost in visibility. Thanks Jeff.
    E911SR & RGRUPPE
    '73 S Coupe #306
  6. #46
    Apr 2011
    Kent- Think that at least the red LED brake lights are very smart. All cars on the road these have third high mounted brake lights.
    Several years ago I had a driver come very close to the back of the S claiming she couldn't see my brake lights. I immediately ordered them.
    I also picked yellow LEDs for the turn signal bulbs. Kept the original lens but when blinker on it looks yellow.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  7. #47
    Feb 2010
    San Francisco, CA
    Done! Thanks Jeff.
    I'm now running a hybrid of the Audette "brighter" incandescent bulbs with the LED brake light bulbs referenced above. Also splurged and put in some warm LED dome light bulbs. I'm keeping the dim instrument lighting as I like the look.
    All dialed in (for now).
    E911SR & RGRUPPE
    '73 S Coupe #306
  8. #48
    Aug 2010
    Any updates on these LED's
  9. #49
    Apr 2011
    Continue to be very glad I installed the LEDs. Really like the yellow turn signals un stock red lenses.
    Every so often have turn signal flasher issues- either doesnt flash or .... rapidly. Tried a suggested solid state turn signal relay but same problem(s). Next I'm going to do a real close inspection of the four light housing grounds.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. FS: 911R tail light housings and bulbs
    By ETW in forum For Sale: 911 Parts
    Last Post: 03-04-2014, 05:43 PM
  2. FS: Early 911 Light Buckets And Bulbs
    By jwoods in forum For Sale: 911 Parts
    Last Post: 02-02-2014, 08:37 AM
  3. LED tail light bulbs for '65-'73
    By Baron in forum Technical Info
    Last Post: 09-25-2012, 11:17 AM
  4. fog light bulbs
    By Walter Stockton in forum Technical Info
    Last Post: 04-24-2009, 07:08 AM
  5. FS: Period Light Bulbs 12V, 6V, LOT?
    By MoparBoy72 in forum For Sale: 911 Parts
    Last Post: 05-31-2008, 10:45 AM
