Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: LED light bulbs
  1. #11
    Odd - I use them in my cars and have never had to change the flashers. Worked great out of the box and bought them at Kragen of all places...they work great as a stopgap fix for dim taillights, as they require less current to go full bright than tungsten filament bulbs. I've never been happier with tail light bulbs than with LEDs.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  2. #12
    Ok...I'm convinced. Who is the recommended source for led's to upgrade my 72 911's tail and brake light bulbs...with the plug 'n play version. Also, what led part numbers do I need to do this?
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
  3. #13
    Member Doc72's Avatar
    Aug 2012
    Montreal, Quebec, Canada
    Quote Originally Posted by FL-Frank View Post
    Same question, '72 specific.
    Frederic D - #2405
    Cogita Mori - Vivere Disce
    Betty '72T, 3.0L PMOs, STRish body.
  4. #14
    I purchased the LED bulbs from a seller on eBay. Nobody in particular, just the best price with a good seller rating. In fact the seller was from Hong Kong and there were no issues with receiving the product. The bulbs I used (see the photos further up in this thread) are SMD LED. These have LED panels that are situated so that when then illuminate, they reflect off the inside of your light housings. Buy red LED for the brake light, yellow for the turn signal, etc. The key is the bulb color needs to match the color of the lens it will shine through. Search eBay with terms SMD LED 1157, for example for a 1157 type bulb.
  5. #15
    another safety plus to LED is that they come on MUCH sooner than regular bulbs, replace one brake bulb and have someone push the pedal, you'll be amazed.
  6. #16
    Jun 2003
    Bend, Oregon
    There's a bewildering array of LEDs available. Can anyone provide specifics? 15d, 12d, etc.
    JohnA
  7. #17
    For an 1157 running/stop light these should work just fine. These sellers likely have the other bulbs you need as well, such as 1156 amber for turn signals & white for backup lights. Search for 1156 LED SMD amber
    http://www.ebay.com/itm/2-1157-RED-4...1abefa&vxp=mtr
    http://www.ebay.com/itm/12V-24-SMD-L...68f547&vxp=mtr
    http://www.ebay.com/itm/2x-1157-2057...18e6ac&vxp=mtr
    http://www.ebay.com/itm/1157-Car-27-...item1e6c319035
    http://www.ebay.com/itm/2-X-1157-BAY...ef1175&vxp=mtr
  8. #18
    Junior Member
    Dec 2010
    Jacksonville, FL
    Hey All,
    I just want to thank the contributors for all the great links!
    This is my next project... after the rear window defroster replacement.
    Someone over on Pelican had come up with LED replacements for the instrument lights that had the correct load and dimmed properly. Does anybody know of that product or an equivalent one?
    Thanks!
    -Dan
  9. #19
    Jul 2012
    Claremont,CA
    There is a new brand that all the ricers swear by. NOKIA.. it outperforms most of the LED out in the market and are not the taiwan ones. They actually in packaging boxes. I think they are made in KOREA and in Japan.
    2cents
    Porschegal
    CEO of the Best early 911 parts store in Southern California
    www.Schnellautosports.com
  10. #20
    Apr 2011
    N.Calif., south of SF
    Porschegal
    Do you have a link for these?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  1. FS: 911R tail light housings and bulbs
    By ETW in forum For Sale: 911 Parts
    Last Post: 03-04-2014, 05:43 PM
  2. FS: Early 911 Light Buckets And Bulbs
    By jwoods in forum For Sale: 911 Parts
    Last Post: 02-02-2014, 08:37 AM
  3. LED tail light bulbs for '65-'73
    By Baron in forum Technical Info
    Last Post: 09-25-2012, 11:17 AM
  4. fog light bulbs
    By Walter Stockton in forum Technical Info
    Last Post: 04-24-2009, 07:08 AM
  5. FS: Period Light Bulbs 12V, 6V, LOT?
    By MoparBoy72 in forum For Sale: 911 Parts
    Last Post: 05-31-2008, 10:45 AM
