Different "Nokia", it is actually spelled "Nokya".
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
I bought some tail light LED's (66 911)from one of the links here to Ebay. They are brighter when on running lights but when you hit the brakes(with lights on) they do not get much brighter. You can't tell I have applied the brakes(unsafe). They were Red Led's for the brake lights. Anyone have a lead to a better LED for a safe set-up?
Good quetion
James Hurst #1638
R Gruppe #514
I used recommended LEDs from SuperbrightLEDs.com, for all my external lamps except headlamps. 73 911 targa, original flasher. All work fine, no complaints. Much brighter, and I like the "instant on" effect. I did use some license plate bolts with embedded LEDs from AutoZone as well. They are great with my 91 deck lid w/o plate lamps.
Bill Conway, Early S Registry member #254
1970 S, 2.2L Silvermetallic Coupe
1973 T, 3.2L Black Carrera Targa
1969 T, 2.4L Silvermetallic Targa
I notice that SuperbrightLEDs.com has 15 different 7528 (tail light) bulb substitutions available. Which one did you go with Bill? I'm thinking that these might provide a little more safety from being rear ended.
Kent
E911SR & RGRUPPE
'73 S Coupe #306
I bought my red LED's from superbright also but the brake light is not much brighter then the running light. I sent them an email but have not received a return email. I tried their bulb locator but it does not list Porsche. Bill which bulbs (#) did you buy, there are so many to choose from. I did see these http://www.superbrightleds.com/morei...sher/923/2274/, looks like they flash 3 times then stay on, sounds like they are also pretty bright. Our light are pretty low so I want to get as bright(safe) as possible.
I went to superbrightleds.com, used their configurator and ended up on this page .....
http://www.superbrightleds.com/cat/l...11--/49-204--/
Haasman
Registry #2489
R Gruppe #722
65 911 #302580
70 914-6 #9140431874
73 911s #9113300709
Wanted to revive this thread. I bought LED from superbrights # 1156 & 1157 these are the ones with 45 bulbs ($25.00 each). I found the brake lights to be a little brighter. When I put the turn signal bulbs in (front&rear) the flasher would not flash ( burn steady). When I put in just the rears the flasher works(fast) but I lost the inside (gauge) indicator light. I have the original flasher still in the car. Has anyone used the electronic flasher unit? Did it help? Thanks for any thoughts.
Bob M
