Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: LED light bulbs
  1. #31
    On my '71 911 it was necessary to replace the flasher in order for the LED turn signal bulbs to work correctly. Here's a post on Pelican that describes what needs to be done: http://forums.pelicanparts.com/porsc...r-problem.html
  2. #32
    Senior Member bobm's Avatar
    Aug 2011
    Northern California
    Mine is a 1966. Did you replace just the flasher unit or did you go through the complete system as suggested in the pelican thread. Which electronic flasher did you use & where purchased.
    Bob
  3. #33
    Senior Member setho's Avatar
    Dec 2012
    New York
    I just put LEDs in my gauges. Since it's so easy to undo, I went white and not yellow.
    I can actually see them at night now.
    Seth O.
    ESR #2474
    1966 911 - '77 2.7L Hot Rod
    1967 Pontiac Bonneville - '70 455
    2000 996
    WANTED: 1966 Transaxle 229835-902/1
  4. #34
    Quote Originally Posted by bobm View Post
    Bob
    Yes, I replaced the flasher with one purchased from Superbrightleds.com I don't recall the part number, however, you will be able to figure it out the one you need on the superbrightled.com website.
    After removing the Porsche 4 pin flasher and replacing it with the newer BMW 3 pin flasher you follow step 6 in the instructions from the Pelican forum post:
    6) If you look at the back of the sockets for the left and right indicator bulbs in the rev-counter, you will se that they both have two wires attached to them via spade terminals. Using the new terminals and extra wire that you have, you are going to replace the part of the circuit that feeds the signal back to the missing relay pin so that it goes to earth (negative terminal on the battery!!). Good news is that you can do it all on the back of the rev-counter
  5. #35
    Dec 2009
    Copenhagen, Denmark
    Order with SuperBrightLEDS has been placed. I'm going to hold off on the turn signals and just do brake lights and reverse lights. Thanks for the info guys!
    James Hurst #1638
    R Gruppe #514
  6. #36
    LED bulbs aren't DOT approved mainly because of their narrow beam angle, especially in a typical narrow form factor. However, their response time is superior.
    To ensure as wide a beam pattern possible, I would recommend sourcing a bulb with as many LED elements as will fit into the housing. I've had a 9-element LED for years, but these 1", 1.25" or 1.85" LED cluster are probably superior. The manufacturer, Radiantz, has been around for many years. These LED clusters are available in a wired bulb base or as a single unit bulb.
    http://www.radiantz.com/index1.html?c16.html&1
    Sherwood (No affiliation)
    48 element, 1.85" cluster
  7. #37
    Aug 2011
    Northern California
    I bought the LED 1157 & 1156 bulbs from Superbright. When first installed the turn signals would flash really slow and I lost the interior (speedo) flasher light. I bought a 3 prong electronic flasher unit
    (10.00 @ local auto parts store) and it plugged right into the original socket, you have to ground the unit with the supplied black ground wire. Once installed the lights work great, even got back the interior(speedo) light, the new electronic flasher also makes a nice clicking sound so you can hear if you leave your blinkers on. I also replaced, the back-up and the license lights. Lights are brighter, I feel safer and Mama's happy
  8. #38
    Apr 2011
    N.Calif., south of SF
    I really like yellow turn signals on the back of cars. Seems to attract much more attention than red ones.
    I discovered while installing LED lights in the '73 that a yellow LED bulb under stock red tail light lens shows yellow when on! Love it.
    Name:  LED tail lights L off.jpg
    Name:  LED tail lights L on.jpg
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  9. #39
    Aug 2011
    Eugene, OR
    Quote Originally Posted by 911pcars View Post
    To ensure as wide a beam pattern possible, I would recommend sourcing a bulb with as many LED elements as will fit into the housing. I've had a 9-element LED for years...
    I've had these installed in both of my 911s. Bought the first set something like 7 years ago. 48 LEDs per board, and when packed into the round pattern, they don't look like LEDs when lit. Easy install, totally reversible, no cutting, drilling, etc.
    Spokeworks LED RS-style brake lights
    Name:  Screen Shot 2020-09-30 at 7.59.12 PM.jpg
    My only criticism was that the tail lights were too bright, so there wasn't as much difference between tail and brake as I wanted. When I mentioned that to Jerry (the man behind the lights) he said the tail lights could be easily dimmed by removing two of the three resistors on each circuit board. That was what I did on the pair in the Carrera 3.2.
    When I bought a new pair for the 72T I mentioned that I would probably be pulling those resistors, and he said that since he generally builds to order, he'd just build me a pair that way.
    I love mine. Instant response, and virtually undetectable. And VERY bright.
    - Arne
  10. #40
    Jun 2012
    London, Ontario, Canada
    Jerry built the LED clusters for the custom Triumph Thruxton I built many years ago. Bright lights are pretty key on a bike too!
    Early 911S Registry # 2395
  1. FS: 911R tail light housings and bulbs
    By ETW in forum For Sale: 911 Parts
    Last Post: 03-04-2014, 05:43 PM
  2. FS: Early 911 Light Buckets And Bulbs
    By jwoods in forum For Sale: 911 Parts
    Last Post: 02-02-2014, 08:37 AM
  3. LED tail light bulbs for '65-'73
    By Baron in forum Technical Info
    Last Post: 09-25-2012, 11:17 AM
  4. fog light bulbs
    By Walter Stockton in forum Technical Info
    Last Post: 04-24-2009, 07:08 AM
  5. FS: Period Light Bulbs 12V, 6V, LOT?
    By MoparBoy72 in forum For Sale: 911 Parts
    Last Post: 05-31-2008, 10:45 AM
