Putting my doors back together and can't work out where these go
TIA
Tony
TIA
Tony
Tony
I believe they act as washers where the screws that hold the window channels in place bolt to the door.....might be off to the right in the photo, or could be '64'
Sonett43 has it right. Here's a pic (from a '70):
Mike
Mike Caterino
1970 T targa
Santa Barbara, CA
restoration blog: mk911.blogspot.com
# 64 is at the bottom inside of the door holding the frame in place.
Your right though thay are lock washers for the two bolts that hold the front top of the alloy frames to the door
usually hidden behind 2 rubber plugs
Hex head bolts are on panel 8/7 however washers are not shown anywhere I can find.
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
Slide in from bottom hole and push up make sure folded edge is facing out at the the bottom as per the pic
Clyde Boyer
please mark this day....it is not only the day I am right....but also, the very first time an internet forum agreed on the answer to a question.....
the world will never be the same.
You too?
Sonnet, Mike and Clyde, thank you so much, going into place today...... I hate having spare parts.
Tony
The two bolts that install at that point are SHORT! don't remember the exact length but seems like they are shorter than the other similar bolts retaining the window frame. If they are too long they will put pressure on the felt channel.
Can't you just feel the love in this sort of thread a complete reversal to a couple of other threads running currently
Clyde Boyer
