Thread: Steering column/hub toothing
    Aug 2009
    Germany HG
    As we are in the process doing of a (very) small batch of RS/RSR steering wheel hub extensions with around 65-70mm thickness I need a technical drawing or the exact specifications of the inner hub toothing to continue with the CAD. Could anybody here help me on this?
    Christian
    RGruppe #649
    Early911S #1788
    If you are referring to a hub spacer for an early 911 style wheel, you dont have to worry about the splines. The hub spacer fits between the steering wheel and the splined portion.
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Aug 2009
    Germany HG
    Thanks David. Perhaps a bit misleading but I was not referring to a spacer but a one piece 'thick' hub with splines - something like on this picture here:
    So still looking for help regarding the spline/ toothing measurements...
    Christian
    RGruppe #649
    Early911S #1788
  1. Steering column lock
    By kenikh in forum General Info
    Last Post: 02-11-2022, 10:48 AM
  2. WTB: 911 Steering column column cover (LWB)
    By RSwannabe in forum For Sale: 911 Parts
    Last Post: 04-22-2013, 07:25 AM
  3. Replies: 3
    Last Post: 02-09-2013, 04:06 PM
  4. Steering column removal help
    By mpotvin in forum Technical Info
    Last Post: 10-08-2012, 10:37 AM
  5. SWB Steering Rack, shaft up to the steering column
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 01-12-2012, 07:11 PM
