Hi guys , can someone help me on this unit and advise age / correctness / etc... having trouble putting a date of build to it andif it is correct or been messed with.
John Gausden
Auckland, New Zealand
(shipping carson,CA)
Early911nz.org
ST-Classic.com
ST-Classic Facebook
Hi John,
It looks to be a 50s - 60s TWM1 alloy case Twin, made prior to the plastic case Twins TWM2s that were released in the late 60s/70s.
The 4 non original Phillips screws likely housed an Avco small exterior light set; which now looks to have been supplanted by the large central light awning. The 4 original plastic knobs have been replaced by some hand cut brass (?) ones.
The factory decals have long since faded or the case has been repainted black- the correct finish is a 'crackle' matt black. Open and see if the gear carrier is there and the internals.....these are super robust but they need to be mechanically complete.
Cheers
SCK
'65 901 SA '119' - 1st RHD Customer Delivered 911 Worldwide; 5710 Stone Grey/Green Leatherette 3 owners from new.
'75 (Nov) 924 Group 4 Rallye. 9th o/all, 1st in class ‘79 Repco Round Australia Rally Barth/Kussmaul; 1st RHD chassis, 1st front engined Porsche to win an FIA event
‘78 928 Manual - early RHD Opalmetallic (gold) + Pasha
'98 986
‘99 996 GT3 CS M003 ex Peter Fitzgerald. Falken livery. 2nd 2000, 3rd in 2001 Aus Nations Cup Championsip. Last of the road registered racers
The back of it should have the Model No and a Serial number and from this you should be able to roughly date when it was manufactured.
heres the rear and numbers , metal case but it has twm2 stamped
John Gausden
Early911nz.org
ST-Classic.com
ST-Classic Facebook
It looks like some one swapped the case.
Question. Can you post a picture of the side w/o the small cover? That will show how the original lighting was. There are basically 3 sorts of Twinmasters: early alu early style lighting (TWM1 very low serial number), alu later style lighting (TWM1) and last plastic later style lighting (TWM2).
BTW while at it, are your 2 lenses clear or black w/ a white dot as can be seen on the picture posted by fellow board member "1st".
Richard
ok , i will have this in stock on the weekend as it was part of a deal of parts i was doing , will list for sale now but will add lots of photos over the weekend
John Gausden
Early911nz.org
ST-Classic.com
ST-Classic Facebook
Ok lots of photos , it is a ali case front and rear and it is a tmw2 stamp on the rear so it,s genuine case .
John Gausden
Early911nz.org
ST-Classic.com
ST-Classic Facebook
And more picsplus
John Gausden
Early911nz.org
ST-Classic.com
ST-Classic Facebook
