Thread: replacements for switch light rod/tube?
    Dec 2004
    SE Michigan
    I have a few missing or broken light rods in some switches. I assume there is no source for direct replacements...
    Has anyone sourced an optically clear 4mm rod to make replacements?
    I have the rubber knobs on my '68, so the fact that the end would not be rounded is not an issue.
    Thanks for the ideas!
    Bill G.
    EarlyS #718 | RGruppe #437
    Dec 2006
    Las Cruces, New Mexico
    I have used this source http://www.mcmaster.com/#standard-plastic-rods/=irv4sm
    If you want an exact 4mm chuck larger size piece of rod up in a drill motor use 180 grit sand paper in 10 seconds you will have 4mm.
    Site is ROYAL pain to navigate. Click "impact resistant clear/color polycarbonate. Left side first product.
    Early 911S member #166
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Yep just replaced mine, plastic/rubber place 4mm rod in hand.
    Tony
  1. LWB (Rubber Knob) Fog Switch and Driving Light Switch FS
    Last Post: 06-22-2012, 06:37 PM
  2. Replies: 1
    Last Post: 03-09-2012, 07:18 PM
  3. Replies: 0
    Last Post: 09-11-2011, 08:42 PM
  4. FS-NOS fog light/warning light switch in porsche box
    Last Post: 09-11-2010, 09:42 AM
