Thread: 1971 911S 2.2 MFI Engine Bay Fuse box question
    I have a 1971 911S with 2.2 and MFI all original. There is a 3 fuse fusebox on the left rear of the engine compartment. Does anyone know quickly, what the top fuse is connected to? And if it should energize when the ignition switch is turnd on? Needless to say, it is not energizing with the switch on, and I don't recall if it should. Also, is this fuse supplied via another fuse from the front? Item 10 in the below diagram, top fuse. Thanks Allan
    1974 914 2.0 Yellow/Black
    http://www.pelicanparts.com/911/911_...l_diagrams.htm
    Greetings,
    I believe that the top fuse is energized when the ignition switch is on and that the circuit is fused with fuse 7 or 8 on the 10 position fuse block in the front. I've provided a link to decent wiring diagrams, located on the Pelican website, to help verify the wiring. I hope that this helps.
    regards,
    Al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    I'm down in Monterey for the Historics and don't have my diagrams, but the three are for: rear window defogger, rear wiper, and MFI speed control...or something for the MFI....T cars only had a two fuse box.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Look at SL35 (the factory manual wiring diagram for T,E,S) on this link:
    http://members.rennlist.org/911pcars/WiringDiag.htm
    Item #80
    1969 S Coupe #761
    Early S Registry #1624
  1. 1971 911S Targa- Engine # question
    By CVLCPorsche in forum General Info
    Last Post: 05-02-2012, 08:37 PM
  2. For Sale ; 1969 - 1971 911S Engine Bay Oil Console / Thermostat
    Last Post: 10-10-2011, 05:42 PM
  3. Wtb. Cardboard that covers the fuse box on a 1971 T
    By mpgandco in forum For Sale: 911 Parts
    Last Post: 10-29-2008, 09:20 PM
  4. 1971 911S Finally done and a tech question
    Last Post: 01-03-2007, 08:37 PM
  5. Wanted : exceptional condition rear engine lid grill for 1971 911S
    By RPMClassic in forum For Sale: 911 Parts
    Last Post: 03-14-2006, 01:27 AM
