Results 1 to 9 of 9
Thread: '70S numbers matching Targa on the Samba $36k
    Move quickly if you want this one.
    No pictures
    Orig. Signal Orange - now Black
    aluminum decklid
    carbs installed no MFI
    not mine
    http://www.thesamba.com/vw/classifie...php?id=1345647
    From the ad
    1970 Porsche 911S Targa
    This is a matching numbers car: Serial # 9110310125, engine # 6300289, transmission # 711398 along with aluminum rear deck and odometer show’s 87,210 miles. The original color 1410 - Signal Orange repainted Black in 1998. No evidence of rust or of collision damage and paint quality is 7.5. Has some road rash on the front spoiler and rear steel flares. The gas tank has been restored, the electrical system converted to single 12 volt Optima. MFI was changed to Weber’s along with the following: Perma Tune ignition, short gears, Quaife LSD, and SSI exchangers. The Fuchs 7 & 8's x 15 with silver anodized spokes and black background refinished by Robert Woods. In past 2 years the accelerator pedal and linkage, clutch cable, rebuilt shifter and replaced coupler plus light/signal controller on steering column. The doors were changed 1998 for latter model with power windows and fixed vent windows. Owner purchased period correct driver and passenger side vent window assembly's separately on line 5 years ago not installed. Owner has 56+ receipts from 1998 to present totaling over $25,000. $17,000 was spent ’98 – ’99. The car was serviced 8-2-12 at Protech Motorsports, Greenville, SC and is in excellent mechanical condition. They went thru the car and changed Oil and filter, Valvoline max 20W50 (live in the South), replaced the starter relay, adjusted carbs(cleaned low speed jets).
    This is not a garage queen; it has been driven & enjoyed. The previous three owners were long time members of the PCA and Early 911S Registry. Owner is also a PCA & Early S member.
    Jun 2010
    CT US
    Not really a fan of the 4 banger 356
    but this Grateful Dead tribute one is pretty kool from the same seller.
    What a long strange trip its been
    http://www.thesamba.com/vw/classifie...php?id=1312448
    Quote Originally Posted by nickb4 View Post
    . . . Move quickly if you want this one . . . MFI was changed to Weber’s . . .
    Seen this mentioned in several ads for cars --- and I'm curious
    I'm familiar w/some of the asking prices for MFI bits ---pumps (in various states), injectors, lines, etc
    But does anybody have any recent + relevant experience in finding/restoring + re-installing/tuning a once-missing MFI set-up?
    What kind of time/money would this sort of project involve?
    Roughly?
    9110310125
    Reference . . .
    VIN = 9110310125
    . . . and a little bit more here . . .
    http://www.early911sregistry.org/for...ght=9110310125
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    Roughly?
    Far from an expert, but been there, done that. Parts are available. The biggie will be the pump. Several reputable sources for rebuilding, but can't go wrong with Gus @ Pacific Fuel Injection. I think you can budget $3500-4K for that item, unless you want some particularly exotic setup. I'd budget an additional $2k - $2500 for the rest of the MFI-specific bits, depending on how patient you are and the reconditioning work required to bring back to within spec, if necessary. If you are lucky, the drive pulley will still be attached to the left camshaft and the seal won't be leaking. Stock air cleaned recommened and I'd also go for the metal air horns inside the air cleaner, even if the nylon ones are more correct. Metal ones are less prone to melting/burning.
    That was my experience. Your mileage may vary.
    - MR
    Senior Member prez!'s Avatar
    May 2010
    Atlanta GA
    Roughly?
    I just went through this and the parts are available. I suggest anyone that has had MFI removed located and secure these parts now because they will only get harder to find. The key is have a good calibrated pump and throttle bodies with tight shafts you want as little play as possible. I suggest anyone buying a pump to send it to Robert Cunningham at Fairchild Industries in Redding CA. If the bearings and space cam have no wear it will just need an internal cleaning and calibration on the flow bench. This was the case with my pump with a very minimal charge. I purchased a complete MFI setup for my E two years ago and just had it installed about 4 months ago. Depending on who you use allow around 8 hours labor for install.
    R Gruppe #631
    Early 911S Registry #1825
    1973E Coupe
    Thanks for those replies, You Guys . . .
    Drive 911's - Shoot 1911's gan911s's Avatar
    Jul 2007
    The 70 S Targa is heading to the "Fatherland" after the particulars are worked out. 9110310125 was posted on Samba, Excellence classified and eBay. Great exposure and activity generated by all the sites.
  1. 1969 911s value matching numbers vs non matching
    By frankmar in forum General Info
    Last Post: 02-26-2015, 09:53 AM
  2. FS: 1971 911T Targa Matching Numbers Project
    By sparkie993 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 11-12-2013, 04:53 AM
  3. This car was actually a 73E, numbers matching
    By WM711 in forum General Info
    Last Post: 05-30-2010, 11:42 AM
  4. New Guy Matching numbers?
    By wanna911s in forum General Info
    Last Post: 04-21-2008, 10:19 PM
