Thread: FS - Air Filter System for High Butterfly's
    I'm thinking of selling my air filter system for the high butterflies. I've been going through all my parts and this is something
    I know I'm not going to be using, so rather than sit on the shelf it should go to someone who actually does use their car!
    It's a pretty special piece of kit that I've been developing and making over the past 18 months, based on a set of original
    50mm SCRS composite manifolds and short trumpets that are collectors items in themselves. They sit in the carriers from
    the earlier carburetor car which have been modified and bored out to the high butterfly's 50mm and then the metal airbox
    again from the 69-71 era cars sits on top.
    This airbox is the one to use as it has a higher more rounded design over the trumpets than the later plastic box so giving
    a better air flow. The box itself is very heavily modified with a new back section incorporating an open grill cover and a
    fabricated seating flange for the optional K & N racing air filter. The front cover again is redesigned with a new grill and inner
    flange to locate the air filter. All new seals, gaskets and bolts are used everywhere and the later larger airbox catches are
    utilised for quick release. The box also has the inbuilt fuel squirter tubes if you wanted to rig up a cold start primer button.
    It's all been finished off by a specialist powdercoater to a fantastic standard and looks great, it's the best way to protect a
    special engine with high butterfly's from ingesting crap, but still look original at the same time.
    Here are a set of pictures of the system including one of the SCRS manifolds during their restoration, interesting in that it
    shows the aluminum inserts for the 5mm bolts.
    Price is $2850 plus the shipping from the UK.
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
    Hi Mike,
    Email sent
    Matt
    Quote Originally Posted by Matt Blast View Post
    Hi Mike,
    Email sent
    Matt
    You better reproduce these, Matt.
    -Marco
    TLG Auto: Website
    Sale pending.
    cheers, Mike
    Member#1664
    +1.................
    Quote Originally Posted by nickb4 View Post
    Mike,
    Beautiful work
    Richard aka le Zookeeper
    early reg #1128
  1. Replies: 1
    Last Post: 08-25-2013, 07:58 AM
  2. Restoring Hockey Pucks & Butterfly's
    By jaudette3 in forum Technical Info
    Last Post: 02-19-2013, 09:14 AM
  3. Replies: 0
    Last Post: 02-28-2012, 08:51 AM
  4. New high asking price for a 2.4S MFI system?
    By kenikh in forum For Sale: 911 Parts
    Last Post: 07-25-2005, 05:54 PM
  5. Oil Temperature - How High?
    By hdavis in forum Technical Info
    Last Post: 05-30-2005, 08:48 AM
