Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: WTB Snorkel Alternative
    Port Macquarie, Australia
    Hi Guys
    I'm chasing something a little more bespoke than a cut down snorkel for my airbox...
    I've seen some interesting intake "grills" for the airbox which appear to replace the snorkel cover altogether. I anyone doing this sort of thing for sale?
    John Forcier
    EarlyS #1987
    Restoration Saga
    Sep 2006
    Maryland
    I've always been a bit curious about the OEM design. Does anyone know why it has that long snout? Does it increase the velocity of the air?
    Sorry for going off topic........Bump
    Rob Abbott
    Sep 2006
    Maryland
    Interesting, I never noticed but if you pointed it straight up it looks like a giant velocity stack.
    Rob Abbott
    Senior Member prez!'s Avatar
    May 2010
    Atlanta GA
    I have wondered about this as well. It's a cleaner look. I like this one.
    R Gruppe #631
    Early 911S Registry #1825
    1973E Coupe
    Oct 2009
    Indiana
    I'm no expert, but it was my understanding that the snorkel was designed to draw heat off the engine, as well as providing warm air to aid combustion.
    That said, the snorkel was always ugly, and the other alternatives are more aesthetically pleasing.
    Physics Guy oscillon's Avatar
    Sep 2010
    Washington DC
    From what little I know of fluid flow ;-), the snorkel appears to have a classic Venturi design. I haven't measured the angles on the inward flare, or the "tube" section of the snorkel, but they seem pretty close to a 30deg followed by a 5deg shape. This shape helps to reduce drag, while also decreasing the pressure (resulting in an increase in flow velocity at the entrance), which may have been a design consideration. Being a fan of a prominent proboscis, I think it's form and function at its finest.
    ______________________________________________
    Dan B.
    1966 911 black/red
    1966 912 slate grey
    1996 993 black/tan
    Sep 2006
    Maryland
    Quote Originally Posted by mshaver51 View Post
    I don't think its to provide warm air, that is something to be avoided. Cool air is much more desirable, because it is denser and will expand more, creating more power.
    Rob Abbott
    Apr 2011
    N.Calif., south of SF
    On the earlier cars I have always believed that the snorkel design was to ensure water would not be ingested by the engine through the engine cover grill (driving rain storm), attachment point for the oil tank breather to catch fumes, and to help reduce intake noise to meet the strictest European standard of Switzerland. Designed to be off to the side so that these requirements were met and not directly in the way of some service items. One can still reach spark plugs with it on, for instance.
    I don't believe it was designed to help the engine ingest hot air.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Feb 2010
    San Francisco, CA
    I've always been interested in the fabspeed "cup" intake. (as long as you paint the carbon weave flat black)
    http://www.fabspeed.com/911_2.html
    There was someone else out there making an SCRS type intake.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Jul 2006
    Corvallis, OR
    I ended up just making my own. I used 914 engine lid steel mesh material. I've had my engine on the dyno at Rothsport for the last few days. We tried different snorkels and modified snorkels and my piece. Jeff has one that he made that has no steel mesh and what looks like the top of a spittoon welded to it for better air flow. All in all they were all very close in HP. Mine was about 1 HP less because of the mesh material. The biggest difference was removing the filter. You get more HP without a filter but you suck dirt.
    72S, 72T now ST
  1. Is there an alternative to LoJack
    By maspirito in forum General Info
    Last Post: 03-30-2014, 06:50 PM
  2. Red banjo horns alternative source?
    By HughH in forum General Info
    Last Post: 03-23-2013, 05:13 PM
  3. Light alternative to fuchs ? What happened to VTO ?
    By Greg D. in forum General Info
    Last Post: 09-25-2012, 01:12 PM
  4. Any alternative to Air Cleaner box on MFI eng
    By 1TRICK6 in forum Technical Info
    Last Post: 10-19-2011, 11:58 AM
  5. is there a cheaper alternative for Michelin XWX????
    By turfclubroad in forum Technical Info
    Last Post: 11-30-2004, 06:45 PM
