Results 1 to 9 of 9
Thread: 2012 Thread on Battery Solutions
    Porsche - There Is No Substitute 2POINT7's Avatar
    May 2005
    After unsuccessfully searching the forum for good, current ideas for the best battery solutions, I decided to start a new thread as things do change over time. In my '73S I currently have twin Interstate U911-50 batteries, installed in July 2005. Although they still start the car fine, I've probably stretched the life out of these 65 month batteries as they are now 85 months old.
    Interstate's website says these have been discontinued and can no longer be ordered http://www.interstatebatteries.com/c...ement++battery so I'm looking for the best solution, and i am not particularly keen on the Optima products. My preference is to keep two batteries that fit as if stock.
    What do you think is the preferred solution in today's market?
    Ed Cave
    Atlanta, GA
    Member No. 738
    1958 Porsche 356A Sunroof Coupe
    1998 Porsche Carrera S
    2008 Porsche Carrera S (her dd)
    2013 Audi A7 (my dd)
    If you want to change nothing the sonnenshchein (wrong spelling for sure) like ed mayo uses are the best. expensive though.
    Jul 2006
    Corvallis, OR
    I bought two U911's from Marco TLG a few months ago. They are solid black in color. I'm sure there's still enough of them around that you could find some locally. You could order them from Porsche and get the Porsche name on them. They will cost more of course.
    72S, 72T now ST
    Jul 2006
    Corvallis, OR
    There you go. That's what I have.
    Quote Originally Posted by geshaghi View Post
    Interstate sells a different version now:
    http://www.interstatebatteries.com/c...Battery_All%29
    72S, 72T now ST
    Apr 2003
    Portland, OR
    I think you can also get twin replacements fron Por$che. The pn is 999 611 014 91. According to the Bird they are $192.75 ea (http://www.pelicanparts.com/cgi-bin/...iption=BATTERY)
    or you can try Sonnenschein (http://www.sonnenschein.org/) A512/40 units.
    Harry
    Member #789
    2009 MB C300
    Oct 2010
    Florida
    I've had both Porsche and Interstate. No real difference. My Interstate dealer couldn't find that 911 battery last month so I went with Porsche.
    btw - I've had good luck replacing one battery at a time. When everything goes dead I just replace the weakest battery. I'm good for a couple more years.
    Richard Newton
    Sep 2006
    San Francisco
    I had bad luck with the Sonnenscheins. They just didn't last. Right now I'm running gel type batteries that are made and sized for a Miata. They are smaller so I have to put a block behind them to allow the straps to tighten properly. They were about $100 each so even if they don't last long I won't feel to bad.
    Jeff Jensen
    May 2005
    Thanks, guys. I purchased two of the new version Interstates today. Done.
    Ed Cave
    Atlanta, GA
    Member No. 738
  1. Replies: 1
  2. Seatbelt Solutions for early 911??
    By 964RS UK in forum General Info
    Last Post: 05-27-2013, 03:56 PM
  3. Bike rack solutions for targa?
    By 16vsilverstreak in forum General Info
    Last Post: 11-23-2012, 07:29 AM
  4. Replies: 10
    Last Post: 05-29-2012, 03:12 PM
  5. Twin battery to single battery conversion
    By bulldog in forum Technical Info
    Last Post: 03-30-2002, 09:44 PM
Tags for this Thread
