I have reorganized my collection of early Porsche parts and have several new offerings.
Contact me if you see something you want or even if you are interested in a related item. I probably have it. I am selling the following now:
1. (5)3-pin CDI units 12 MO warantee-$400, with rebuildable exchange-$250.
2. (5) Weltmeister Gated short shifters-Porsche body(05 or 06) and custom Seine gate-$250. Add $55 for knob and $19 for new boot.
3. (4)SC brass 28 tube($350) and (4)Carrera ($550) coolers-(new shock mounts,
short oil lines, and mounting hrdwr). Terbarol oil cooler($250). B&B oil cooler w lines $550. Flexible AN16 Aeroquip oil cooler lines,thermostat and fittings($550)-complete front to back setup. Oil plate cooler kits-$250. Carrera or radiator stone guards NOS ($75)(upper only).
4. Mocal Oil Thermostat AOT2 -$100. AN12 fittings for Mocal-$20, SC/Carrera Oil
Thermostat-911.107.163.OR (good threads)-$250.
5. 1970-2 911 rubber oil Lines (inquire)
6. (1)180 MPH (mechanical) Carrera rebuilt speedo-$450.
(1)2.2L 911S (70/71) $TBD Mag. Stacks
(4)2.4L 911E (72/73) $TBD Plastic stacks
(2)2.2L 911E (70/71) $TBD Mag. stacks
(1)2.0L 911E (69) $2750 Mag. stacks
(10)2.4L 911T (72/73) $TBD Plastic stacks
8. PARTIAL MFI SYSTEMS OR PARTS PLEASE INQUIRE-injectors(6 untested or
tested)$375-TBD, fuel consoles, pumps, air boxes, etc. e.g. 1969 2.0L 911S stacks and throttle bodies.
9. (3)1972 911S oil console-$395, (5)1972 911T oil console-$300.
10. Volvo Turbo fuel pump/regulated for MFI applications(3 port direct substitute for Bosch 001)-pressure and flow tested-$325
(3)1972 911 $350-750(mint), (1)sporto $350, (3)1966-1971 911 $250-500(mint).
12. (1)1969-1973 headlights $100, two-stage rear window $75, fog light $150 switches.
13. 911 (1969-1973) mufflers-(2), Bursch(2/1), flowmaster shorties (1/1)x2-($125).
14. Late(aluminum) 915 Transmission noses $150.
15. New clutch plate for 1972 915 (225mm) $139.
16. New reproduction aluminum license panel (1969-73) from Restoration Design $95. Early 911 jacks –good to excellent condition – used $75-125.
17. Front and rear fiberglass RS bumpers- $250-350 each.
18. TTG 1969-73 fog lights-restored Hella TN2,4&6($550&$250), Used $250-150. Fog
light covers-$125 Give your car that special look. Inexpensive European substitutes-
$150-350. Free reproduction mounting brackets with purchases over $375.
19. Good starter motors 69-73 $75-125.
20. Used working MFI electric fuel pumps-flow tested to spec.(data supplied)-$425. Special- Leaking MFI fuel pump repair $150 (flow tested)
21. 1978 SC ring and pinion gears-mint condition-$650.
22. Parting out 1978 915 transmission-make requests-$TBD.
23. Rebuilt shift couplers with new bearings-$65.
24. Slightly used 911 main bearing set .25mm under (German)-$150.
25. 915 SC differential $125. SC drive flanges (fine spline) $125.
*Included are the following: pump support bracket and AL spacer, oil breather plate with cold start thermostat, oil line to pump, fuel console with bracket and filter, 6 fuel lines, 6 fuel injectors, free moving MFI pump with good pulley, throttle stacks, bodies, crossbar, and linkages, air filter housing, air filter, and snorkel, flapper box for 72/73 air intake.
Inquire about additional parts. 20 years of early 911 collected parts mainly 1970-3. Pictures available upon request. ( X) indicates units available. email: pgeorge911@aol.com, Telephone 952 835-9969
