Hi Guys,
I thought this document may be of some help for anyone mounting a set of Hella 128's Happy Labor Day weekend.
Best regards,
Brad
Hi Guys,
Best regards,
Brad
Brad Davis
RGruppe #691
Early 911S #1547
Document upload is not very high res. PM me if you would like me to email over the original with all the fine detials.
Brad
Brad Davis
RGruppe #691
Early 911S #1547
Brad, PM sent for high res document.
I have a set of Hella 128's that I would like to mount on my '70T. Would anyone have a picture(s) or document showing how they are actually mounted on the lower bumper. Thanks.
My fog lights work only when my headlights are on position 1 (only sidelights on).
Shouldn't the fog lights be linked to position 2 instead: only working when low beam/high beams are on?
Hi Brad...
Very kind of you to offer a copy of this. I'd like one - john at audettecollection dot com
Best Regards,
P.S. No surprise - your message box is full.
”Lighting Resources for Hardcore Air-Cooled Porsche Enthusiasts”
My foglight brackets have 2 holes at the bottom of the bracket for mounting. It looks like I need one hole near the top in order to mount the Hella 128's. Can someone confirm this and perhaps exactly where the hole should be. I've never liked drilling holes so before I commit I'll wait to hear from the collective. Many thanks.
Brad,
I would love a copy or hi res PDF.
Please pm me once your inbox clears up.
Mark
1967 911S - 306465
1980 911SC
2005 Carrera Cabriolet
Hi Guys,
Sorry for the delay. I have sent out high res instructions to all PMs. John and Mark, I will send your email copy asap.
Best regards,
Brad
Brad Davis
RGruppe #691
Early 911S #1547
Can anyone with Hella 128's show me a picture of your mounting? Here are the holes in my fog light bracket. As you can see I have 2 at the bottom and none at the top, which is where I assume I need a hole. Just need to know where exactly, how far down from the edge, unless the holes I have can be used, but can't see it. Many thanks.
