Thread: Collective wisdom required??
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Question Collective wisdom required??
    Looking for help of suggestions.
    Has anyone had success repairing a terminal on the back of the dash switches?
    Putting my dash back together, when pop! One of the terminals at the back of my 69 hazard/flasher switch came off in my hand!!!!
    Can I just drill out the rest of the rivet, or does it travel all the way down inside the switch??
    It is the R terminal that snapped, so another thought was to put a doubbler on the L terminal, as it looks like it's power to the indicators?
    Thanks for help and suggestions.
    Tony
    Port Macquarie, Australia
    Tony, you could probably use a doubler.
    These switches as you know are a 'one year only' item, but they are still available. Mine is also broken (the shaft). If you want to source out a new one, I'll buy your current one to help defray cost?
    John Forcier
    EarlyS #1987
    Restoration Saga
    Nov 2004
    Gold Coast.
    Yeah I might try the doupler, new where'd you see them new??
    Tony
  1. Replies: 31
    Last Post: 09-23-2013, 05:27 AM
  2. Collective wisdom from the group 1976 Turbo
    By rpsurfr in forum Other Porsche Passions
    Last Post: 09-30-2011, 08:51 PM
  3. Any Wisdom on best car cover to use in heavy snow & sun?
    By 2008SPorsche in forum General Info
    Last Post: 04-08-2010, 11:22 AM
  4. Words of Wisdom from 1996
    By 911s911rs in forum General Info
    Last Post: 12-11-2004, 08:16 AM
  5. Collective Wisdom Sought
    Last Post: 12-20-2003, 03:05 PM
