Thread: Long hood project - Back on track
    Had a short break while I finished a few other project, now back to my long hood project.
    Goal is an R type hot rod, dual use street and track car.
    Reminder of the start, decent tub project, blasted and turbo flared.
    Started laying out the fender operation tonight. Marked the trim areas on the tub. I need to keep the rear light opening from the earlier car, as the 75 brake light opening is a different stamping.
    Outer rockers will be changed too, pass side has a big welded cut in it.
    Drivers side will probably take a more traditional flare type cut.
    And a rocker
    Rocker and rest of the pass fender came off finally. Inner rockers is a bit crusty, so I'll go ahead and replace it while it's open.
    John Helgesen, ESR member #2003
    Stahlwerks.com
    Took more rust off today, and found more. Having fun now.
    New stuff to go back
    Trimmed the fender to fit today. Another few dozen spot welds cut out.
    Stahlwerks.com
    Fit the new inner rocker.
    Built a few patches at parts from scratch.
    Test fit the outer rocker.
    Stahlwerks.com
    Senior Member C.Plavan's Avatar
    Mar 2005
    Clovis, Ca
    Where did you get that body cart? I need one like that badly.
    Chad
    911ST Race Car w/2.5L SS race motor.
    1972 911 T- Original numbers car- restoring it
    2016 Elan NP01 Prototype Chassis #20; Car Number #02
    2011 Porsche Spyder Wht/Blk/ Carbon Fiber Buckets (Sold)
    Powered by Faragallah (Aase Motors)
    Thanks Chad, the cart is built from roll bar tube and casters for scaffolding I had left over. The car sits on the torsion tube and the front crossmember bolts. Center section unbolts for storage.
    Stahlwerks.com
    Started aligning the front fender and door to check the rocker parts. I'm using some fenders and doors from a 75 I have to work with. Not perfect, but straight.
    Door gap needs more space.
    Needs to be perfect before I secure the rocker.
    Stahlwerks.com
  1. Bringing a '69 911S Back to Life--Long Overdue Intro
    By David Taylor in forum General Info
    Last Post: 11-26-2021, 11:27 PM
  2. FS: Long Hood Trunk Cover - Front Hood - from a ’71 911
    By m1franck in forum For Sale: 911 Parts
    Last Post: 11-29-2013, 03:39 PM
  3. New toy 70's r-gruppe back date project
    By advtracing in forum Other Porsche Passions
    Last Post: 11-16-2012, 11:34 PM
  4. WTB: Hood latch and Reciever for a Long Hood.
    By C.Plavan in forum For Sale: 911 Parts
    Last Post: 04-04-2012, 03:56 PM
  5. track car project
    By admin_old in forum General Info
    Last Post: 02-13-2004, 01:48 PM
