Thread: Warning contact on brake master cylinder?
    Look at the picture, there are two wires with connectors, both has brown wires. The warning contact has only one connector. Is the warning contact un-original? any way to connect and use the one I have?
    thanks
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Looks like one of the posts on the switch is broken/missing. It's a simple ground circuit that activates the brake lights, that's why both wires are brown. looks like you need a new switch
    John Schiavone
    Connecticut
    Actually the switch is not broken, it just has one terminal/connector and a very small rubber cap in the middle protecting a small transparent plastic pin. I guess I will have to buy a new switch.
    Both wires are brown except 1 has a stripe on it used only for the 2 wire sensor. You can use the single post sensor though while NOT using the solid brown wire. To reset the dash warning light simply press the stemmed button on the single post sensor.
  1. Need Brake Master Cylinder Piston
    By red911 in forum Technical Info
    Last Post: 10-08-2011, 09:40 PM
  2. Brake Master Cylinder 23mm New
    By Dmill in forum For Sale: 911 Parts
    Last Post: 09-24-2011, 05:21 AM
  3. Brake Master Cylinder Warning Switch
    By HarryD in forum Technical Info
    Last Post: 01-05-2007, 02:08 PM
  4. Brake Master cylinder renewal?
    By Dennis in forum Technical Info
    Last Post: 08-03-2005, 05:42 AM
  5. Brake master cylinder
    By herrongrey66 in forum Technical Info
    Last Post: 09-12-2002, 11:54 PM
