Thread: H4 wiring question
    H4 wiring question
    I have three wires in my factory socket, and I swapped over to H4s from Pelican. My headlights on low beam are very dim, my brights are excellent. Reading some posts, it's possible I have my ground on the wrong terminal, but before I remove the PITA H4 housings, I thought I'd seek verification.
    I have three wires: white, yellow, and brown. As I understand it, the white is the low beam, yellow is the high beam, and the brown is the ground.
    Now the new H4 socket has three terminals, two vertical and one horizontal. Looking at it with the horizontal one on top, I wired the white to the left, yellow to the horizontal on top, and the brown to the right. After reading some, it's possible I need to swap the white and the brown? Can I get a confirmation on this?
    - Brian
    1966 Mercedes 250SE Cab
    Sep 2011
    Los Angeles California , subburbs
    POS,
    h4 are current hogs. maybe it would be nice to relay both lights. ground makes a big difference . i ground out the buttom pin.. drill a small hole in the buckets..and ground there..it will make a difference..
    lemon
    schnell autosports.
    This is all I could find at the moment. This is shown with relays, but the wire colors appear correct.
    Yeah, I did find out about the relay add-on in my readings. If I wired correctly, then this is what I'll have to do. However, in your diagram above, I have the white and the brown switched. I haven't driven the Porsche much in the dark lately, so I'll do the dual relays and fix my swapped wires all at the same time. Thanks.
    - Brian
    Brian, yellow is low beam, white is high,
    Jul 2012
    Claremont,CA
    dont touch the bulbs with your fingers. The oil in your fingers makes the a hot spot in the bulbs.. They have new japanese bulbs that out perform hella ones. more white..by Nokia in H4
    2cents
    Porschegal
    CEO of the Best early 911 parts store in Southern California
    www.Schnellautosports.com
  1. MFI Microswitch Wiring Question
    By justacoupe in forum Technical Info
    Last Post: 01-13-2014, 09:22 AM
  2. 71 Engine wiring Question
    By John912 in forum Technical Info
    Last Post: 11-10-2010, 04:32 AM
  3. Cibie Wiring Question
    By Max (SD) in forum Technical Info
    Last Post: 11-19-2008, 12:47 PM
  4. simple wiring question for TTG...
    By Kaleid in forum Technical Info
    Last Post: 05-13-2008, 07:56 PM
  5. Wiring Question(s)
    By Paul Schooley in forum Technical Info
    Last Post: 02-19-2008, 10:55 AM
